can you determine if the thermo fans (located on the radiator) are functioning at all when hot?
You should hear them turning on and off, and if you switch the air-conditioner on, they should both be on! If not then this is the issue and its a simple electrical fault.
Also, is there any cream coloured sludge being deposited on the inside of you oil filler cap? If so, this means you have a head gasket issue.
finally, do you get any white smoke out the exhaust when idling, if so then even more certain of head gasket issue.
Let me know how you go with these few checks.
