Page 67 of 93 FirstFirst ... 175763646566676869707177 ... LastLast
Results 661 to 670 of 926
    #661
    Quote Originally Posted by vc23 View Post
    Inahabol ko rin ground clearance. Nagfloflood talaga yung area pinupuntahan ko....
    Bumili ka na lang ng pickup kung talagang bahain mga lugar pinupuntahan mo.
    Oct 2018
    #662
    If i wanted to buy a f×××ing pickup, i would have gone with a pickup. Siguro naman maiisip mo rin saan mo ipaparada yang pick up na yan kung wala kang parking space. Kung wala kang magandang maisagot, wag ka ng sumagot.
    Jan 2014
    #663
    I think it's better not to risk yourself and your car if the place is really flooded. There would be downside when you wade your vehicle through floods even if it has a high ground clearance.
    Even if my vehicle have high ground clearance I take detours
    Sent from my SM-A700FD using Tapatalk
    Feb 2014
    #664
    the pickup suggestion was totally reasonable. if you're going to be rude like that then just leave
    so i recommend a pickup for you also, just to piss you off
    Oct 2018
    #665
    Quote Originally Posted by Vodka View Post
    Naa, i wont be leaving, but suggesting a pick up is really rude.
    #666
    I was just being straightforward and practical in suggesting a pickup if you are frequenting flood-prone areas. They are built to withstand such punishment.
    The Rush is a bit under-powered and its low grunt may not pull you out of deep flood water. The Ecosport may have a deep wading depth but it is not advisable for such small crossovers to go thru flood waters.
    You're the one who's rude with such an answer.
    #667
    Quote Originally Posted by crosswind View Post
    +1
    I drive a crossover with a high ground clearance but I ain't taking chances going thru flood waters unless I am sure my vehicle can cross it safely.
    Jan 2014
    #668
    +1
    If the Camry can do it, I will follow. If a pick up truck can do it(I also use a truck) and most suvs are taking detours doon nalang ako sa mas safe kahit medyo flooded rin.
    Our vehicles nowadays have a lot of electronic components. Even the ABS light may light up if you pass through floods which was the case with a friend of mine who drives a truck too.
    Jan 2014
    #669
    He wasn't being rude. As a truck owner I would suggest you get a truck too. Trucks nowadays have better ride comfort than a Toyota Rush
    #670
    No dude, you're the rude one here. What's wrong with suggesting a pickup?
All new Toyota Rush/ Daihatsu Terios
