Results 661 to 670 of 926
October 12th, 2018 02:53 PM #661
- Oct 2018
- 4
October 12th, 2018 03:11 PM #662
October 12th, 2018 03:18 PM #663
I think it's better not to risk yourself and your car if the place is really flooded. There would be downside when you wade your vehicle through floods even if it has a high ground clearance.
Even if my vehicle have high ground clearance I take detours
Sent from my SM-A700FD using Tapatalk
- Feb 2014
- 2,694
October 12th, 2018 03:27 PM #664
- Oct 2018
- 4
October 12th, 2018 03:33 PM #665
October 12th, 2018 03:50 PM #666
I was just being straightforward and practical in suggesting a pickup if you are frequenting flood-prone areas. They are built to withstand such punishment.
The Rush is a bit under-powered and its low grunt may not pull you out of deep flood water. The Ecosport may have a deep wading depth but it is not advisable for such small crossovers to go thru flood waters.
You're the one who's rude with such an answer.
October 12th, 2018 03:53 PM #667
October 12th, 2018 03:56 PM #668
If the Camry can do it, I will follow. If a pick up truck can do it(I also use a truck) and most suvs are taking detours doon nalang ako sa mas safe kahit medyo flooded rin.
Our vehicles nowadays have a lot of electronic components. Even the ABS light may light up if you pass through floods which was the case with a friend of mine who drives a truck too.
October 12th, 2018 03:59 PM #669
October 12th, 2018 04:07 PM #670
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
