Sir, I have 2015 vios E, ano po model ng oil filter natin? saka ano size para makabili ako ng sariling oil filter wrench? Thanks!
its time for me to replace tires (all 4)... have already canvass for specs but I got different answers... some say yes, some no... I was hoping for actual experience
I want my tires (if possible) to be bigger (higher) with stock mags (e model)
stock tires are 185,60,15R... so I was hoping 185,65,15R
One store said its possible w/o rubbing or any issue.... some store tells me its not possible...
Anyone tried this set up?...
I know its not visually nice, but my car is literally our "workhorse" vehicle for errands, for some rough roads, etc... any clearance will be helpful
Thanks
when faced with issues, i stick to stock. there is probably a reason why the manufacturer determined what size the tires should be.
sometimes, the answer may be something not easily felt, until some time, maybe months or years, after the switch.
errr... sumayad na ba ilalim ng sasakyan nyo, or are you "thinking ahead"?
kung hindi pa naman sumayad, e... wag na kayong magpalit ng tire size.
good luck, po.
btw, if the tire circumference changes from stock, it will probably throw off the odometer's and speedometer's readings "a bit". are you willing to live with this?
The car is regularly driven hard by different drivers, including me... I have the usual sayad like entering a driveway w/o caution, humps when car is fully loaded (or over loaded) by kids (other driver is a college kid)
Anyway, I can live with scrapes and scratches as long as car is reliable and mechanically sound.
I just see an opportunity once I change tires... I have done this before with a Nissan Exalta... and I like the effect... boaty in a way ;-) but that was guaranteed by the tire supplier that it wont scrape.
I just want to be sure (if anyone has experience), because I don't like the idea of going back to the Tire supplier and argue if it did scrape.
If I don't get a definitive answer, your very much right, that I will stick to stock.
Thanks for the reply
I've always bought one size wider tires than stock. Never had a problem with sayad. With my 2012 2nd gen E, I went from 175/65/r14 to 185/65/r14. Feel became a little bouncy. But cornering and comfort improved. And IMHO it looked subtly nicer because of the higher profile.
Check out the difference here:
185/6 -R15 vs 195/6 -R15 Tire Comparison - Tire Size Calculator | Tacoma World
weirdo talaga ng casa
nakalagay sa manual eh replace brake fluid every 2 years, pero pinilit ng SA na sa 40,000km pa daw yun :D
oh well
Actually parang technically he's correct sir. Kasi kung susundin strictly yung 5k kms or every 3mos (standard PMS), technically every year, 20k kms ang dapat itatakbo mo.. And 40k kms ang itatakbo mo on your 2nd year. Pero yun nga, strictly following that condition yun sir..
Sent from my LG-H860 using Tsikot Forums mobile app
these are guidelines, po, not laws.
SAs can not "pilit". they can only recommend, and you can always decline. my favorite line is, "wag na muna, bossing. wala sa budget, e".
i'd follow the manual. it's on paper for you to sue with. the SA has only his voice.
and you can be like me and others like me. we interpret the pms on the cheapest cost basis.
Mga paps ask ko lng and share ko lng experience ko yesterday,i was in the middle of the road driving,medyo traffic so nag stop ako then nag total blackout vios e 2014 ko,so i start it again gumana nman,ano kya prob ng auto ko?
[QUOTE=midnytwarrior;2571483]Para sa akin subjective na lang ang paglalagay ng mud guard. Yun sa akin hinde ko naman pinalagyan kaya hinde ko rin alam saan pwede magpalagay o bumili.
Wait na lang po natin ibang mga ka tsikot natin baka alam nila saan pwede bumili.
Sir good day,
Ask ko lang kung ano maaaring problema ng car alarm ng toyota vios 1.3E namin. Supposed to be ma trigger ang alarm nito if sususian w/o unlocking. Hindi na po siya nagana kahit ilan beses ko na i test. Tnx and Godspeed...
Sir good day,
Sir good day,
Ask ko lang kung ano maaaring problema ng car alarm ng toyota vios 1.3E namin. Supposed to be ma trigger ang alarm nito if sususian w/o unlocking. Hindi na po siya nagana kahit ilan beses ko na i test. Tnx and Godspeed...![]()
Sir good day,
there are several types of car alarm, po. some came from the factory, some were installed by the casa, and still some were installed in banawe, araneta, or evangelista.
if your alarm came from the factory or the casa, you will have to ask the casa, exactly what is it that your car has, and what features it offers.
i do not know about vios E, but my innova E did not come with an alarm. i had to buy one.
Vios 1.3E came with toyota's OEM alarm. As far as I know, Trigger Ay electronic Lang via door ajar and and ignition. Try mo nga Kung nagana yung door ajar light sa map/dome lights. Pag nag o on ang ilaw pag bukas mo ng pinto, Baka yung alarm na my problema. Try mo din open trunk lid na naka arm yung alarm, dapat mag alarm din.
