own a 2013 vios 1.3E... also have 2 regular keys, and 1 button type...
base on experience, i have to share the keys to a driver as well... I get to use the keyless entry... but if i forget to NOT to engage it (when i know the driver will use the car next).... driver will just open the door manually... (alarm will engage)... but all he has to do is start the engine (using the regular key)... the alarm will stop, and the car, car locks will just work properly....
so no real issues on my part who carries what key...
just my 2 cents
[QUOTE=mcdip;2511198]sir yuki maybe only toyota vehicle security system
Is this how immobilizers work?
If I remember correctly the story told to me, the gf of my barkada pressed the remote locked button while inside her Focus, she then tried to start the car and the alam was triggered. Due to panic, instead of pressing the unlock button to stop the alarm she retried to start the car. After that, she could no longer start the car.
AFAIK Es do not have immobilizers so the method above works. There is a page in the manual that shows the difference between keys with and without immobilizers.
Cars with immobilizers will only start if the key with the chip is inside the car. There might be extra logic in there that prevents the car from starting when the alarm is tripped.
There are alternatives...
1. Buy another oem key from toyota (around 16k)... Yes i did ask before
2. Buy a 3rd party alarm (around 5k)... You can have it work with the oem key... But i dont like the idea of having two different remotes... Also had a Bad experience in the long run... If one of the alam fails... Puwede maging immobile yun car
3. Just live w/ what toyota gave us (2regular and 1 button key)... I chose number 3... Was even considering to remove the battery of the button key, para lahat manual... But end of the day, im just conscious whether i engage the alarm (button) or not....
Just my 2 cents
pang isang tao lang pala talaga yung keys kung ganun ang setup.. o well nakakatakot lang kasi na andali natin masasalisihan if ever sa mga dark places na nakakaalam ng ganitong system nung vios
first pag pindot mo kasi nung wireless, automatic unlock na lahat ng doors.
pano kung magisa ka lang? [emoji33]
amateur enthusiast posting probably from a nexus device
Mga sir normal ba na parang kumakatok makina pag over shift?
1.3 E MT unit.
Example, naka third gear ako, then when I come to a street corner, need ko magbawas ng speed as I turn.
Instead of shifting to 2nd gear, I stay at 3rd gear kasi parang kaya pa naman.
Thats when I hear na parang may kumakatok.
Yung sound nya is parang may nilagay kang something sa electric fan blades.
Is this normal?
Thanks
1.3 E MT unit.
Is this normal?
Thanks
