Page 280 of 286 FirstFirst ... 180230270276277278279280281282283284 ... LastLast
Results 5,581 to 5,600 of 8996
    i must confess, that i do not know whether the vios has a cabin domelight behind the driver's head or not. if there is, you might want to replace the standard bulb inside, with a battery of LEDs. they are easily available, even in the mall.
    if there is none, you can inquire on where you can have one installed. but i doubt if the casa will be willing to install one in your car. they are usually averse to "modifications". ganito: if the higher variant has a cabin light, then they will probably be willing to install you one. but if even the high end variant has none, then they probably will not want to install one.
    void the warranty? only if something goes wrong, po. and it will usually be limited to the electrical system only.
    i do not think upgrading your map lights will shed light on the back seats enough for you. they are designed to light up your lap, not the rear seats.
    good luck, po.
    The Vios only has maplights. No provision for a dome light in the middle either. Casa definitely won't do that for you.
    Your only options are to get brighter maplights, or reduce your tint for more ambient light.
    Jul 2016
    Hi jut703, thank you again for your advice. Will scout for brighter maplights
    Jan 2016
    Sirs, recommendable 16inch rims for 2015 Vios Orange?Many Thanks...
    Sent from my LG-H818 using Tapatalk
    Jan 2016
    Going to Casa next week to have this one checked.
    ano po gamit nyong compre insurance expired na ung sa akin ? looking for maganda at murang insurance
    Quote Originally Posted by doodzie View Post
    try casa.
    believe it or not, natatawaran yan.
    also, do you really need AOG?
    Jan 2009
    Patulong naman po mga boss, got a vios E and its time for a tire replacement. Ano po ma ipapayo nyo?
    Stick with stock tire size 185 60 R15 or 195 55 R15, which is better in terms of fuel economy and etc.. thanks..
    Apr 2012
    Quote Originally Posted by waybrief View Post
    Replace my stock Yomohama 185/60R15 with Kumho KH17 186/65R15
    Much better than the stock tires
    In terms of fuel economy, the narrower tires (185/60R15) would be better, but only very slightly.
    The 195/55R15 is also smaller by 1.3% so you're speedometer reading which is already off by 7%, will be even less accurate.
    The advantage of the 195 over the 185 is that it has slightly better handling because of the wider contact with the road and the smaller sidewall.
    Bottomline, if you don't drive fast on corners, just stick with the stock size.
    Jun 2005
    Get a written quote from your old provider.
    Then ask 2 more insurance companies fo written quote.
    Choose what insurance company you prefer then contact that company and ask for lowering of premium based on the quotes of competitors.
    Laki ng baba ng premium nyan.
    Better ride with the bigger profile im guessing..
    Apr 2012
    It's more quiet than the Db. Driven in the same route with same terrain and lubaks.
    Chosen this cause it's cheaper than the BlueEarth.
    And my DB went bad before i replace it
    Here what it looks like iIMG]http://uploads.tapatalk-cdn.com/20161022/22714e83464bc74425fe8a5c227c61f0.jpg[/IMG]
    Jul 2017
    Sir good day,
    Ask ko lang kung ano maaaring problema ng car alarm ng toyota vios 1.3E namin. Supposed to be ma trigger ang alarm nito if sususian w/o unlocking. Hindi na po siya nagana kahit ilan beses ko na i test. Tnx and Godspeed...
    Quote Originally Posted by Lee J View Post
    Sir good day,
    there are several types of car alarm, po. some came from the factory, some were installed by the casa, and still some were installed in banawe, araneta, or evangelista.
    if your alarm came from the factory or the casa, you will have to ask the casa, exactly what is it that your car has, and what features it offers.
    i do not know about vios E, but my innova E did not come with an alarm. i had to buy one.
    Jul 2017
    I think ours came from the casa itself. Do you know where the sensor is placed so I can take a look at it myself Sir/Mam? It just might have some loose connections..TIA
    alas! i do not. sorry.
    Vios 1.3E came with toyota's OEM alarm. As far as I know, Trigger Ay electronic Lang via door ajar and and ignition. Try mo nga Kung nagana yung door ajar light sa map/dome lights. Pag nag o on ang ilaw pag bukas mo ng pinto, Baka yung alarm na my problema. Try mo din open trunk lid na naka arm yung alarm, dapat mag alarm din.
    May 2013
    Yun DB habang nagluluma at napupudpod apektado accelaration. Parang ang bigat tumakbo ng car
    Sent from my SM-J700H using Tapatalk
    Quote Originally Posted by andsmv View Post
    Had my dB for over 30,000 km with no loss of acceleration. That said, the stock tires of the Vios are mere Aspec dBs and not Advan dBs so obviously there's not much to it. But there's really not much performance you can get out of the Vios 1.3 anyway so no need for grippy tires.
    Oct 2016
    Pa help naman po ano magandang tint for vios 3M ir Vkool? medium black po. ok ba ang visibility pag gabi thanks
All New 2013 Toyota Vios (3rd Gen)
