Results 8,671 to 8,680 of 8993
October 22nd, 2016 08:27 PM #8671
Better ride with the bigger profile im guessing..
October 22nd, 2016 08:32 PM #8672
In terms of fuel economy, the narrower tires (185/60R15) would be better, but only very slightly.
The 195/55R15 is also smaller by 1.3% so you're speedometer reading which is already off by 7%, will be even less accurate.
The advantage of the 195 over the 185 is that it has slightly better handling because of the wider contact with the road and the smaller sidewall.
Bottomline, if you don't drive fast on corners, just stick with the stock size.
- Jan 2009
- 9
October 22nd, 2016 08:59 PM #8673Thanks for the heads up mga boss, I'll stick with the same tire size.
- Apr 2012
- 3,469
October 22nd, 2016 10:56 PM #8674It's more quiet than the Db. Driven in the same route with same terrain and lubaks.
Chosen this cause it's cheaper than the BlueEarth.
And my DB went bad before i replace it
Here what it looks like iIMG]https://uploads.tapatalk-cdn.com/20161022/22714e83464bc74425fe8a5c227c61f0.jpg[/IMG]
Sent from my LG-H818 using Tapatalk
- May 2013
- 140
October 22nd, 2016 11:27 PM #8675Yun DB habang nagluluma at napupudpod apektado accelaration. Parang ang bigat tumakbo ng car
Sent from my SM-J700H using Tapatalk
October 22nd, 2016 11:51 PM #8676
Had my dB for over 30,000 km with no loss of acceleration. That said, the stock tires of the Vios are mere Aspec dBs and not Advan dBs so obviously there's not much to it. But there's really not much performance you can get out of the Vios 1.3 anyway so no need for grippy tires.
- Oct 2016
- 3
October 23rd, 2016 09:50 PM #8677Pa help naman po ano magandang tint for vios 3M ir Vkool? medium black po. ok ba ang visibility pag gabi thanks
- Apr 2012
- 3,469
October 24th, 2016 09:53 AM #8678This is what Db looks like at 35k kms
- May 2013
- 140
October 24th, 2016 10:48 AM #8679
- Apr 2012
- 3,469
October 24th, 2016 11:06 AM #8680
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
