Page 868 of 900 FirstFirst ... 768818858864865866867868869870871872878 ... LastLast
Results 8,671 to 8,680 of 8993
    #8671
    Better ride with the bigger profile im guessing..
    #8672
    Quote Originally Posted by waybrief View Post
    Patulong naman po mga boss, got a vios E and its time for a tire replacement. Ano po ma ipapayo nyo?
    Stick with stock tire size 185 60 R15 or 195 55 R15, which is better in terms of fuel economy and etc.. thanks..
    In terms of fuel economy, the narrower tires (185/60R15) would be better, but only very slightly.
    The 195/55R15 is also smaller by 1.3% so you're speedometer reading which is already off by 7%, will be even less accurate.
    The advantage of the 195 over the 185 is that it has slightly better handling because of the wider contact with the road and the smaller sidewall.
    Bottomline, if you don't drive fast on corners, just stick with the stock size.
    Jan 2009
    #8673
    Thanks for the heads up mga boss, I'll stick with the same tire size.
    Apr 2012
    #8674
    It's more quiet than the Db. Driven in the same route with same terrain and lubaks.
    Chosen this cause it's cheaper than the BlueEarth.
    And my DB went bad before i replace it
    Here what it looks like iIMG]http://uploads.tapatalk-cdn.com/20161022/22714e83464bc74425fe8a5c227c61f0.jpg[/IMG]
    Sent from my LG-H818 using Tapatalk
    May 2013
    #8675
    Yun DB habang nagluluma at napupudpod apektado accelaration. Parang ang bigat tumakbo ng car
    Sent from my SM-J700H using Tapatalk
    #8676
    Quote Originally Posted by andsmv View Post
    Had my dB for over 30,000 km with no loss of acceleration. That said, the stock tires of the Vios are mere Aspec dBs and not Advan dBs so obviously there's not much to it. But there's really not much performance you can get out of the Vios 1.3 anyway so no need for grippy tires.
    Oct 2016
    #8677
    Pa help naman po ano magandang tint for vios 3M ir Vkool? medium black po. ok ba ang visibility pag gabi thanks
    Apr 2012
    #8678
    This is what Db looks like at 35k kms
    May 2013
    #8679
    My DB is currently at 25k. So this means it can run until 35k. Having said that do you still follow recommended 32 30 tire pressure?
    Apr 2012
    #8680
    Yeah of course, regulary checking it. Wala din magaspang na terrain ako na dinadaanan. Dunno why it came out like that before i replaced it
All New 2013 Toyota Vios (3rd Gen)
