Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 324
    Feb 2019
    it's not shameful naman.
    many folks do it all the time... lalona yung walang power locks.
    also, you might try using your key to manually lock the door.
    personally, i do not see the problem.
    Thanks. It’s just so basic and nakakahiya medjo na pa-ulit2 akong ng lock tapos always unlock..haha
    Quote Originally Posted by makinao View Post
    ^ From inside, or outside of the car?
    From the outside. I don’t know whats the exact steps kasi hindi naman all the time nangyayari pero usually pagpark ko, unlock ko ang door using the unlock button above the power window, then paglabas, close ko ang pinto tapos lock ko gamit yung susi. Kahit na may lock mechanical sound, unlock parin. Yung solution ko nalang is buksan ang pinto, lock ko gamit yung key, then cose while pulling the door handle - the classic lock way.
    Mar 2017
    Quote Originally Posted by kitoymonster View Post
    In my experience with Toyota cars, that's weird. The sequence for manual locking should be:
    1. unlock the door to get out of the car
    2. open the door and get out of the car
    3. shut the door
    4. lock the door manually with the key.
    5. just to be sure, pull the door handle. if the door doesn't open, then it is locked.
    Simple. If this doesn't work, its either the door is not completely shut, or there is something wrong with the lock. Complain about it when you take it in for the 1k PMS.
    Jan 2019
    Without using the key, na-try mo na rin ba gamitin yung "lock" button (beside power window lock) habang nasa labas ka na, bago mo isara yung pinto?
    Feb 2019
    Na try ko yan. Yan yata yung issue ko or related to that button. Try ko i-remember ang sequence next time. Maraming beses na to nangyari sakin. Kanina pag park ko sa office nangyari na naman.
    Jan 2019
    Mukhang tama naman yung ginagawa mo. Lock button malapit sa inside door handle, tapos pull mo outside door handle while closing. Ganun din sa owner's manual e. Ako kasi keys na lang para sure din na hindi ko maiwan sa loob. Anyway, pwede naman pa-upgrade na lang sa keyless entry later
    Feb 2019
    Quote Originally Posted by pythoglyphs View Post
    Parang na gets ko na boss. Might need more confirmatory test. Na notice ko lang na even if the door is locked, pwede pala ma open ni driver from the inside.
    Jan 2019
    Yup. From inside pwede mo pa rin mabuksan sa driver side kahit naka lock. Feature yata ito, hindi bug hehe
    Feb 2019
    Parang feature nga. I checked this earlier and from lock -> unlocked position yung switch if na open mo from the inside.
    Feb 2019
    Accidentally set my tranny from Drive to Reverse. Hopefully walang nasira [emoji17]
    Jun 2005
    Di mo naman magagawa yan while car is in motion....
    Gate shifters ang xe, i honestly doubt you can so thia by accident
    Sent from my MI MAX 2 using Tapatalk
    Jun 2008
    Quote Originally Posted by sirkosero View Post
    True, saka from drive dadaan muna sa neutral papuntang reverse.
    Feb 2019
    I did. Walang lock. What happened is I wanted to check the engine braking sa downhill so I switched from D -> M1 then pagdating ko sa baba, I switched up all the way to reverse instead of right. When I stepped on the gas, na-off ang engine.
    Nov 2016
    Hi po mga sir/ma'am, pwede ba matanong mga may Vios XE kung ilan na record nila fuel efficiency? both city and highway driving po sana. Thanks
    Jun 2005
    Quote Originally Posted by tabachikoi View Post
    That should give you a realistic city drive fuel economy of 8km/li.
    They are using the same engine,tranny and practically same body since 2016
    try googling for it, po.
    vios xe km/li or other similarly-worded queries.
    Jun 2005
    Yout gate shifters look like this. So from M+, to reverse, you need to do the following:
    Go to D
    Move the shifter up to neutral,
    Move the shifter left then move to shifter up to reverse.
    All these while stepping on the brake. Mahirap na accident ito imho....
    Feb 2019
    Go to D
    After I reached the flat, the car was at crawl speed. Then I mindlessly set the tranny to R. No brakes were pressed. But in theory, if this happened only once, may damage ba sa tranny?
    Sometimes, speed humps auto changes my tranny from D to N. Happened twice already.
    Sep 2018
    Im about to get XE, based on the upgrades that was mentioned on prev pages, Im thinkin of putting body kits. Any suggestion as to where? thanks
    Sep 2018
    Thermalyte or Alumina Jade?
    Feb 2019
    Quote Originally Posted by Hilikvs View Post
    Meron din Red Mica Metallic and Freedom White boss
2019 Toyota Vios 1.3 XE
