Results 101 to 110 of 324
- Feb 2019
- 32
February 14th, 2019 12:17 AM #101Hi, I’m also getting mine on friday. Didn’t bother to test drive baka mabanga ko ang test car. Noob question, is it fine to manually downshift on this cvt when going down a steep and long downhill? Do I need to continually downshift by shifting to -M if it goes outside the engine braking speed or does it remain there? My only experience in driving is with my honda jazz gd cvt. Engine braking only happens when speed is around 30kph but it will continue to speed up to 60 or more if I leave it alone even if I set it to L.
- Jan 2019
- 39
February 14th, 2019 07:01 AM #102Basically, here's what the owner's manual says (paraphrased):
When in low gears using shiftmatic mode (M), it stays there as long as you don't rev too high (red line) where the ECU will automatically shift up to protect the engine.
When in high gears using shiftmatic mode, it automatically downshifts when speed is slow, or to M1 if vehicle stops.
You can choose gears from M1 to M7.
- Jun 2005
- 3,774
February 14th, 2019 08:37 AM #103
- Jun 2005
- 3,774
February 14th, 2019 08:39 AM #104
February 14th, 2019 08:55 AM #105
- Feb 2019
- 32
February 14th, 2019 08:55 AM #106
- 54,200
February 14th, 2019 09:00 AM #107
- Feb 2019
- 32
February 14th, 2019 09:45 AM #108honda fit gd surplus po. Me and wifey will drive.
- Jan 2019
- 39
February 14th, 2019 09:50 AM #109Partly true. If hindi naman continuous at hindi naman high RPM/redlining, use engine brakes with the right gear WITH brakes. Pag nag overheat ang brake pads, baka madisgrasya ka pa due to brake fading and loss of control.
Key here is to watch your RPM when engine braking, use breaks as necessary and watch your speed (when driving on steep downhill inclines). Safety first
- Oct 2012
- 4,851
February 14th, 2019 02:39 PM #110
Generally speaking sa lahat ng liquid tire sealant.... Not advisable. Pwede as an emergency last...
Liquid tire sealant
