Page 7 of 11 FirstFirst ... 34567891011 LastLast
Results 121 to 140 of 212
    Sep 2005
    #121
    2017 model diba? konti na lang tapusin mo na yung 3 yrs warranty period.
    Quote Originally Posted by atty.cadmus View Post
    the pms were done at casa. plano kong ilabas na hehe
    Jul 2019
    #122
    yes. and noted. thanks.
    Jul 2019
    #123
    sa mga may wigo po dito.
    pwede po bang makita ang pms job order niyo for 40k and 45k mileage sa odo? thanks
    #124
    Pakisagot daw tanong niya
    upload
    #125
    Every weight counts as consumption.
    #126
    upload
    yes.
    but the amount is so small, we can practically not think about it.
    my opinion.
    Dec 2017
    #127
    upload
    This is difficult to answer as you need to consider the Thermodynamic property on how heat energy can have an acoustic effect on the interiors of the car as you depress the gas pedal notwithstanding the effect of volume of the radio.
    [emoji3]
    Jan 2019
    #128
    mga sir tanong lang,pano ba iactivate ang stock o malarm ng 2019 wigo natin, last time kasi nag alarm xa nung binuksan ko xa ng nakalock tas after a few days khit itry ko buksan mga door s lbas n nkankalock wlang tumutunog, meron b kong dpat gwin..
    #129
    Quote Originally Posted by Merdenoms666 View Post
    if yours is like mine, using the key will de-activate the lock, even if you do not press the deactivate button.
    experiment with yours, po, using several combinations. then tell us what you find out.
    Jan 2019
    #130
    Pano po iactivate sir.
    #131
    "press the activate button on the key fob".
    peruse your owner's manual and see if it is mentioned there.
    Sep 2006
    #132
    upload
    Depende sa kanta, if upbeat then possibly mag induce ng adrenaline rush aapakan ng madiin accelerator, thus coconsumo ng gasolina talaga. ( Facepalm..)
    Jan 2019
    #133
    2 lang po yung button ng remote key, lock and unlock lang.
    check ko din po yung manual.
    May 2018
    #134
    The answer's on page 55 of your owner's manual.
    #135
    despite best effort of the... whoever's responsible,
    the icons of locked padlock and unlocked padlock, still need some explanation...
    Dec 2017
    #136
    I think he is referring to the alarm. It might be that there's a sequence to be followed to activate/deactivate it, i.e., long press "lock" button.
    Going back to the original post, can someone explain how to read this,
    nkankalock
    #137
    my 2014 wigo does not have an alarm. lock and unlock only.
    my owner's manual does not mention alarm. only lock and unlock.
    i wonder, have toyota added audible alarm since?
    naka naka lock.
    Jan 2019
    #138
    Nakalock po yun, sorry for the text..
    Exactly po na yun sana yung gusto ko malaman, if meron ba kong dapat gawin para maactivate ung alarm.if meron po paano?
    Ang nangyayari po kasi, pipindutin ko yung lock sa remote key tapos ittry ko buksan manually yung mga door pero walang tumutunog na alarm. Or wala ba talagang ganun feature ang stock na galing sa casa.
    Dec 2017
    #139
    Thank you typing properly! I can now read your message without difficulty.
    If your car doesn't have the sound indicator for lock and unlock operation, as mentioned by *dr.d, then you can have an aftermarket one be installed.
    If previously you can hear that chirping sound before, then it is possible that you have made it in silent​ mode. The Owner's Manual should have instructions on how to reverse it.
    Jul 2019
    #140
    Mga ka Wigo.
    Pa silip nang 40k pms nyo pls.
    Casa gave me around ten thousand pesos for the pms at 40k mileage.
    I will be waiting for your inputs. Thanks.
2017 Toyota Wigo
