Results 1 to 17 of 17
    Jul 2020
    Hello po, good afternoon. I'm planning to buy a 2004 or a 2005 toyota rav4 po.
    yung mga locally released units po ba dito sa philippines ay may safety features like VEHICLE STABILITY CONTROL/TRACTION CONTROL, ABS and EBD?
    I just want to make sure po since yun po ang habol ko sa pagbili maliban sa specs na gusto ko
    Thank you guys and God bless
    Nov 2017
    Quote Originally Posted by coalslaw View Post
    Only the 4x4 Gen 2 models have ABS+EBD but no VSC/TRC both get airbags though
    T O Y O T A: R A V 4
    Jul 2020
    Quote Originally Posted by LOLZ View Post
    so wala pala talaga eto pa naman din selling point ko in buying a used car. akala ko pa naman din meron kasi standard na daw yung VSC nung 2004 and 2005 Models siguro sa US/EU/JAP lang yung nabasa ko.
    As for the VSC/TRC naging standard na nung 4th gen 2013-2018 RAV4.
    Sent from my SM-N970F using Tsikot Forums mobile app
    bakit kaya ganun sir? hindi sila pare pareho ng mga safety features na nilalabas per region could it be dahil iba ang climate dun?
    Traction control and stability control will come handy if you drive aggressively in corners or like to launch the car quickly from a stop. If you drive in a tame manner, then you will be all right with no traction control and stability control. ABS is a much more important safety feature and also seatbelts.
    Pero iba padin yung meron sir diba extra safety features din yun sayang naman kung wala hahha
    anyway thanks guys sa pag respond nakapag test drive na ako ng 2005 rav4 medyo nainlove ako.
    not sure kung dahil ba magiging first car ko siya kung matuloy or dahil good car talaga siya idrive
    Feb 2018
    mahihirapan ka makabili kung andami mong hinahanap masyado sa Philippine market haha. Mga panahon na yan, di pa uso sa commuter cars yung mga ganyan. Well, they are nice-to-haves for the regular driver.
    NGayon, tinatanggal din yung mga ganyang extra feature sa iba (hyundai etc.) for cost cutting
    Dec 2019
    TMP is well known to be stripping out features of cars and trucks here. Unlike in other countries.
    Like for example the head unit of innova/hilux/fortuner. Still using an AVT head unit instead of toyota head unit used in other countries.
    While now some of their models has reduced stripping some of the features. Unlike the past.
    Like the current rav4, still has some features stripped but they still kept the vsc/trc since the previous gen.
    Nov 2017
    Not as bad as the 1KD being retained for the PHDM Prado on the flipside TMP's love for AVT headunits makes replacing the Corolla/RAV4 Headunits possible if not easier by opting for the 2-din style dashboard instead of the floating tablet design they are using with their toyota headunits for other markets.
    Jun 2011
    Madali nga mag upgrade ng HU ng RAV4 dahil sa 2DIN cabinet niya.
    Based pala sa user manual ng RAV4 LE, JVCKenwood ang HU.
    had to do a double check. tama 1kd pa ang prado and toyota is asking 4.1M pesos! no wonder for every 10 lc200 i see baka 1 lang prado.
    Dec 2019
    Not just Prado...Even the old Hiace commuter (flat nose) and the Hiace cargo panel vans still has the 1KD.
    Dec 2019
    pareho lang ba fuel consumption nito vs camry?
    Sent from my RMX2020 using Tapatalk
    Most likely the same, bro. Lalo na kung same engine.
    Dec 2019
    Might be same with the 2.4L front wheel drive rav4.
    AWD rav4 has lower mpg than 2WD.
    im about to purchase a 2016 RAV awd top of the line variant.around $au24k=840k in pesos..good deal?
    odo = 19,950km
    sunroof, leatherseats, heated seat, satnav, awd..etc
    Quote Originally Posted by ozcity View Post
    odo = 19,950km
    how does it compare with the ballpark figure for such car in your locale?
    some unsolicited advice. 1st thing to consider about this model rav4. as they have the sludge prone 1az-fe engine. check for sludge formation these do not tolerate extended oil change intervals well (>5000kms).
2004 and 2005 Toyota RAV4 Owners
