Page 257 of 265 FirstFirst ... 157207247253254255256257258259260261 ... LastLast
Results 5,121 to 5,140 of 5286
    #5121
    For the brake fluid..theres a tool which will tell you whether it's time to change it or not..its available at any online shopping platformAttachment 35523
    di naman nito ma detect yun nasa lines and sa mismong banjo bolt, dito madalas yun corrosion and possible clog sa brake line
    Dec 2009
    #5122
    ^brake fluids are hygroscopic (absorbs moisture in the air)..this device helps the user assess how much water is in the brake system..water corrodes the metal components of the brake system of any vehicle
    When theres too much water on the brake fluid..its time to change to avert corrosion
    It's not the job of this device to detect corrosion but to prevent it with due competence and diligence from the owner
    Jun 2005
    #5123
    Quote Originally Posted by attyallanlatras View Post
    I have a Fortuner 2016 Diesel A/T with almost 35k odo and my questions are:
    When is the Fuel Filter Change due?
    When is the ATF Change due?
    I do not see any dipstick for the ATF, how would we know how clean or dirty is it?
    The break fluids, when is this changed?
    What about the break pads, when is it due for replacement?
    I have my maintenance done outside of casa and they will just do what I ask them to do...
    Fuel filter can be changed outside every year. Mura lang naman yan.
    Brake fluid, change every year or 2, depende sa budget. Ideally every year. Preno kasi yan.
    ATF, yours is a sealed type kaya wala na dipstick. But it can still be replaced. Drain bolt lang naman and then there is a filling hole. Pwede rin dialysis. Make sure the amount drained is equal to amount filled.
    Brake pad, have your mechanic visually inspect it. Chances are, manipis na ito. So replace mo na lang. I heard brembo pads are cheaper than casa originals.
    I DIY maintenance of my cars so i do the above maintenance myseld, depending gaano ako kasipag and need the exercise.
    Sent from my MI MAX 2 using Tapatalk
    #5124
    fuel filter - sa monty ko 20k kms but nung sinunod ko dami dumi, so i replace every 10-15k kms.
    atf - as long as di contaminated para sa kin and di pa iba kulay.
    brake fluid - same din but ako i use syringe to replace the one in reservoir if ever mag iba kulay.
    brake pads, depende sa gamit yan. visual check.
    #5125
    Sir, this is according to casa SA -- replace ATF, Brake Fluid, and Fuel Filter at 40k kms. Brake pads - replace as needed.
    Also at 40k kms -- replace power steering fluid, and replace differential oil.
    Thanks sa sagot. I will do those maintenance requirements by installment. First, aside as regular change oil and filter ko for the 35k pms. Isabay ko ngayon yung change of fuel filter. Then sa 40km pms, I will also do oil differential change, then as 50km pms, gagawin yung atf change. Para hindi mabigat sa bulsa. Ok kaya yun?
    #5126
    i know pero IMO mas madali yata na palitan nalang as scheduled.
    #5127
    i'd probably follow the schedule in the owner's manual.
    it'd be easier to remember...
    individually or collectively, hindi naman ganon kamahal sila..
    #5128
    Mahal bossing, yung fuel filter pa lang without labor pa lang e mahigit 2k na.. this is aside from change oil and oil filter...
    #5129
    you can change the fuel filter yourself, po.
    it's as easy as tom cruise replacing a memory card under water.
    but seriously, it's DIY-easy. heh heh. google it, po.
    use nitrile gloves to keep your hands clean.
    i use mineral oil only. replace every 5K km.
    Jun 2009
    #5130
    good day sir dati ganyan din ako pero after considering everything ang buhay natin
    hindi pedeng palitan at sir i-condition mo narin ang sarili mo sa gastos talagang ganyan
    milyon ang halaga ng ride mo. nagset aside ako unti unti ng pang PMS para pag dating ng
    sked PMS konti na lang dagdag ko. gulong sir will set you back 30-40k handa ka na rin
    in the long run sa bulsa lang masakit sa ulo wala. just a piece of my experience
    at tama si drd mineral oil will do basta consistent lang ang palit every 5k hindi ka naman
    kuma-karera
    Jan 2008
    #5131
    Follow the service manual... fuel filter should be changed every 20k kms.. mura lang yung filter and 100% can be DIY! Differential oil kahit sa 80k km mo ba palitan..lalo na pag di ka naman na lusong sa tubig baha.. sa ATF walang palitan yan pero to be sure change mo sa 40k kms
    #5132
    I do not have a service manual for my toyota fortuner 2016 only an owners manual. In the owners manual, it does not say when to replace fuel filter. Only oil filter is mentioned. Hope you could share where you got your service manual. That would be helpful
    #5133
    ang aga pala ng diesel magpalit ng fuel filter
    Apr 2012
    #5134
    minsan earlier pa nga sa 20k kms bro. marami latak yung diesel. saka yung mga fuel filters now ay mga element type na at mas mababa microns. tama lang naman para iwas bara sa fuel injectors.
    #5135
    my innova's owner's manual does not mention anything about pms-ing the fuel filter.
    my current filter has been in there for over 100K km now.
    i'm still waiting for the fuel filter icon to light up, before i replace it.
    #5136
    I am curious about that service manual. I also have an innova but there is also no service manual when I got it, only owner's manual. Sir is your innova the diesel one or the gas? They do not have the same fuel filter, right?
    #5137
    diesel sakin.
    i used to have a diesel besta.
    its manual said to replace the filter every 30K km.
    hindi ko pinansin. at 39K km, tinirik ako sa gate namin.
    Apr 2014
    #5138
    Baka nagkamali lang ng sabi. Meron service manual which is available lang sa mga authorized service center, or basically sa casa. Which normally indicates kung paano mga procedures ang dapat sundin ng technician while servicing the vehicle.
    Sa owners manual, nandun sya sa pages or section related sa periodic maintenance. No service procedures at ang naka indicate ang mileage at time interval kung kailan mag inspect and replace specific parts and fluids.
    #5139
    according to my owner's manual:
    the fuel filter of the innova gas engine is to be replaced every 80,000 km or 48 months, whichever comes first.
    the fuel filter of the innova diesel engine, does not need periodic replacement.
    yespo. the innova diesel engine fuel filter and the gas engine fuel filter, do look different from each another.
    #5140
    Mga sir, the maintenance I do on my fortuner 2016 diesel a/t is this:
    Every 5k change oil and filter.
    Every 10k or 15k change air filter sa engine and air filter sa aircon.
    But I need to know when:
    Change atf?
    Change coolant?
    Change break fluid?
    Change rear oil differential?
    Change fuel filter?
    Timing belt or timing chain?
    And for the atf and oil differential, what oil to use?
2016 Toyota Fortuner
