Results 1 to 20 of 44
    Jul 2004
    Drum brakes = cheap, pang masa
    Disc brakes = expensive, sosyal
    Feb 2016
    Akala ko pinaglalaban ng Toyota na mas okay ang rear drum brakes para sa ganun klaseng SUV? right now they updated with rear disc brakes na in Thailand and sooner or later dito na
    Feb 2009
    The process has to be done properly.
    The master cylinder might have to be replaced or, the residual pressure check valve has to be removed from the master cylinder to prevent the rear brakes dragging. Since Toyota brakes is front/rear split, the LSPV (load sensing and proportioning valve might have to be removed. Whatever it is, the kit must have been gingered for the particular vehicle. Do it properly, your unFortuner is not a jeepney.
    what about the handbrake, sir?
    Feb 2009
    Same parking brake lever, same upper parking brake cable, same equalizer bar. Lower park brake cables are different. The rear calipers may be integrated (service brakes and parking brakes using the same friction pads) or disc service and drum parking brakes( like the Corvette's and supras)
2016 Fortuner Rear Wheel Disc Brake Conversion
