Page 34 of 102 FirstFirst ... 243031323334353637384484 ... LastLast
Results 661 to 680 of 2033
    Jun 2006
    #661
    3 cylinder lang yan, talagang maalog compared to a 4 cylinder engine.
    Aug 2011
    #662
    Quote Originally Posted by pinklife View Post
    hi guys question lang sana...yung qigo nyo po ba is panay ba ang shake ng engine? Bale parang shaky?
    Posted via Tsikot Mobile App
    Normal po yan. Normally mas malakas talaga vibration ng 3 cylinder compare to 4 cylinder engine unless maganda ang engine mounting, engine support at transmission support ng sasakyan to lessen the vibrations. Same din ng mirage meron vibrations
    Feb 2014
    #663
    Quote Originally Posted by Tj_abs View Post
    Thanks for the clarification...im enjoying my new wigo...kinakabahab pa lang aq slyt pag nasa road hehhe any tips??
    #664
    Quote Originally Posted by sirkosero View Post
    sa states or any progressive country, oo.
    sa pilipinas, a bolt out of place will be considered as a reason why the engine or any part failed.
    pipilitin pa na yun ang reason para di makapag claim...
    Sent from my Thrill 430x using Tapatalk 2
    We modify cars for work and we have to deal with the dealers with regards to warranty claim. And yes, they have to prove that the modifications were the cause of the problem. Most of the time, they just honor the claim. This is just based on personal experience, btw. . Different units, different dealers (different companies also since I transferred work sometime ago also).
    #665
    err... sir/ma'am pano kayo nakakuha ng driver's license? delikado yan. you're posing danger to other motorists.
    #666
    Naku natatakot na tuloy aq mag drive naka 1st gear pala pag start ko napausod...maliit nlng kulang bangga na huhuhu wew need to practice more
    Feb 2014
    #667
    Quote Originally Posted by smallbody View Post
    Yung kuya ko kasi ngpark nun nkafrst xa pagpark..hindi ko nabantayan na 1st gear..new driver pa kasi...well my fault dq chineck...lessons learned!
    Aug 2013
    #668
    Medyo OT, Does this apply to all 3 cylinder engines?
    Oct 2013
    #669
    ^ no... depende sa design ng engine sabi nga... like for example ford's 1.0L 3 cylinder eco boost...
    Aug 2013
    #670
    Buti hindi ka bumangga, made the same mistake nung bago pa lang din ako nagda-drive. Hehehe...
    Aug 2013
    #671
    Quote Originally Posted by Stigg ma View Post
    Ah ok. May sinabi kasi sa akin yung boss ko na in-design, hindi talaga stable ang 3 cylynder engine kasi hindi siya balanse. Kaya iniisip ko yung mga 3-cyl engine normally ganun talaga.
    Feb 2014
    #672
    Quote Originally Posted by pompeyo View Post
    Hindi naman nasa parking lot lang naman sa bahay namin..kinabahan lang aq kasi napausod hehehe malapit lang nabangga..first time ko talagang mag.on ng wigo q...frst start ko and first hawak sa key hehhee...pero thank god hindi...hehhee careful nlng tlga dapat nxt tym...
    Feb 2014
    #673
    Im sori pero nainsulto aq slyt sa "pano kayo nakakuha ng driver's license?" Di ba pwdeng ngkamali lng frst start ko lang yun at hindi aq nagkuha at ngdrive ng wigo ko nung kinuha sa toyota..first hawak ko pa nga sa key and frst start..nafrst gear ng kuya ko para malock dw..dq lang nabantayan...careful nmn po sana sa pananalita...nobody's perfect...ikaw ba nung frst time mo hindi kaba nagkamali? Perfect ka ba?
    Feb 2014
    #674
    Anyways, lessons learned...sorry sa napost ko di kasi aq makatulog sa kakaisip ng sinabi mo at least napalabas ko...ill be more careful next time=)
    #675
    e papano naman yung 1-cylinder motorsiklo o 2-cylinder motorsiklo? tagal-tagal masira...
    Jun 2013
    #676
    mas stress pa nga ang makina ng motor dahil sa higher revs
    #677
    let's give the 3-cylinder cars a chance to prove themselves here..
    we may not have too many 3-cylindar cars here in RP now, but they are popular models elsewhere..
    as i recall, the daihatsu charade was a 3-cylinder car..
    this early, i already read many positive remarks of them 3-cylinder cars from actual owners..
    Aug 2004
    #678
    Motorcycle engines actually don't last as long as car engines because of the high revs. And balance is an issue on one-cylinder motors. But then, most of our old motorcycles are two-strokes... the new generation EFI four-strokes should have better engine longevity.
    A three is inherently unbalanced, but so is a four-cylinder. This is why many four-cylinder motors nowadays come with balancer shafts or dual-mass flywheels to quell vibrations.
    And yet, most people don't give a second thought to the "unbalanced" nature of inline four-cylinder motors. ;)
    Aug 2012
    #679
    ok lang yan. charged to experience ika nga. iwasan po ang text speak sa forum. just a friendly reminder.
    Jun 2014
    #680
    I'm planning to get a new car but still undecided between Wigo and Mirage. Ramdam po ba ang difference na 200cc?
    Di kasi ako techie pagdating sa kotse. Thanks guys.
2014 Toyota Wigo
