Originally Posted by
vinj
Change the oil every 5,000kms. There are too many cases of sludging already that occured with those who followed the 10K change oil service interval.
Plugs - NGK BKR6E-11
Coolant - Anything red (i just buy the premix at the Toyota dealer) then add in a bottle of RP Purple Ice or Red Line Water Wetter if you want.
PS Fluid - any Dexron III rated ATF will do
Brake Fluid - Prestone DOT 3
Motor Oil - Shell, Caltex, Mobil, Royal Purple, etc... almost any oil with at least API SL/SM rating should do. If you want to avoid any possible leaks, go with 20W40 or 15W-40 weight oil. What's important is you change every 5,000kms.
don't forget to clean the brakes every 10,000kms and have the MAF sensor cleaned as well with some contact cleaner or carb cleaner (its the sensor after the airbox). Have your fuel filter and air filters checked as well.
On the timing belt, the Altis uses a timing chain and this does not need any replacement.
