Owners of toyota Rav4 4x2 2009 or 2010 model need your inputs sa average fuel consumption city driving. Thanks!
bro subjected ang fc depende sa route from moderate to heavy 6-7km/L heavy traffic 5-6km/l but for long trips 8-10km/L sa slex/nlex/sctex 12km/L this is base from my recent 2009 rav 4 (sold)
Its engine, 2AZ-FE, is not exactly new. Its ancient in terms of car years. Its been around since the 2003 Camry 2.4V until the present, as well as the 2004 Previa until the present. It can also found on the newly introduced Alphard.
Even if its old, its not that bad. If only the upgraded the automatic trans on this one from the 4 speed to at least a 5 speed. That way better fuel consumption rates can be achieved on the highways.
ito yong engines na nasa north america for the rav4...
para sa Base 4WD, Sport 4WD, at Limited 4WD...
2.5 Litre, 4-Cylinder, Aluminum Alloy Block, Dual Variable Valve Timing with Intelligence (VVT-i), Sequential Multiport Electronic Fuel Injection, Acoustic Control Induction System (ACIS), Tier 2 Bin 5 Emissions Rating, Heavy Duty Battery, Starter, Alternator and Heater, Stainless Steel Exhaust System
179 (134) * 6,000 rpm
4-Speed, Automatic, Super Electronically Controlled Transmission (Super ECT), Overdrive, Gate Type Shifter, Transmission Cooler
Active Torque Control System, Vehicle Stability Control (VSC), Traction Control (TRAC)
para naman sa Base V6 4WD, Sport V6 4WD, at Limited V6 4WD
3.5 Litre, 6-Cylinder, Aluminum Alloy Block, Dual Variable Valve Timing with Intelligence (VVT-i), Sequential Multiport Electronic Fuel Injection, Tier 2 Bin 5 Emissions Rating, Heavy Duty Battery, Starter, Alternator and Heater, Stainless Steel Exhaust System
269 (201) * 6,200 rpm
5-Speed, Automatic, Super Electronically Controlled Transmission (Super ECT), Overdrive, Gate Type Shifter, Transmission Cooler
Active Torque Control System, Vehicle Stability Control (VSC), Traction Control (TRAC), Hill-start Assist Control (HAC), DAC (Downhill Assist Control)
yong dating 2.4 na engine wala na sya...
...ito naman yong tires ng Base at Limited model..
P225/65R17 Tires, All Season, Radials, Full Size Spare Tire with Steel Wheel
...at ito yong tires ng Sport model..
P235/55R18 Tires, All Season, Radials, Full Size Spare Tire with Alloy Wheel
...magkakaiba ang release nila ng models bawat country.. sana makakatulong ito if ever may mga features dito na wala dyan..pwede nyong ma add on...then sa tires pwede syang palakihan up to 18" wheels pero kailangan sport tuned ang suspension pag di sport ang model.![]()
