Quote Originally Posted by red_one View Post
Share lang. My OEM type LED DRL installed below the foglight. They are connected to a Multi-function Automatic LED DRL controller. The controller can be used with any set of LED DRLs.
When engine is switched on, the DRL will auto on. When headlight is on (night time), the DRL will reduce brightness to 50%. When engine is switched off, the DRL will stay on for 20 seconds before it auto off. When left/right turn signal is on, the corresponding left/right DRL will flash in sync with turn signal while the opposite DRL will turn off. When you use the car horn, the DRL will flash in strobe mode.
You can select which functions to enable by connecting the corresponding wires.
Sent from my D5833 using Tapatalk
Bro red_one may I know how much you spent with the DRL including installation =)
