Page 85 of 134 FirstFirst ... 357581828384858687888995 ... LastLast
Results 1,681 to 1,700 of 2668
    #1681
    BTW here's the first time, i think i posted this somewhere.
    Replacement part was Ando R223 Japan.
    Will try OEM this time.
    Apr 2010
    #1682
    i remembered this post sir. -- i believe you did it DIY and a very clean install as well.. I'm assuming sub standard replacement part?
    #1683
    I hope so, else i will be doing something with the reservoir cap. Parts to arrive by next week.
    Also replaced worn tyres with 8-ply, plus bought a spare fan. I'm hearing bushing noise na kasi and some play with the shaft, expecting it to give in anytime soon.
    #1684
    Found out also that there are 3 rad fan-motor types. Im guessing the application is for non-AC, single, and dual AC. That explains also why there are 4-3-2 pin connectors.
    Apr 2010
    #1685
    ahh... so that's the reason why I get that "vibration" when aircon is on as compared as off.. and sometimes hear it louder when in summer traffic.. so its like a 3 speed motor...?
    #1686
    Yup.. Its a multi-speed motor. Saves space from separate fans, acts as cooling fan for both engine rad and AC condenser.
    Some parts are ready for pickup, will be installing it on weekends.
    #1687
    A supposedly 30mins replacement and bleeding job turned into a nasty 2hr job.
    Yep, i stripped the head of 1 stubborn nut. It's grade 10 and i can't torch it because of fuel lines near the area.
    Ended up grinding and customizing a replacement nut.
    #1688
    Why casa oil must not be extended to 10k kms use
    Sludge
    Apr 2010
    #1689
    you sir.. are a DIY god!!!
    #1690
    ^ Just a DIY maintenance enthusiast sir. Actually, im also enjoying the troubleshooting part. hehe
    Heres some more..
    Damage compliments of a co-worker with heavy hands. She was able to rip the hinge of the handle.
    Tube was crushed by a casa mech. It was a last-touch job, but was too late to complain when i noticed it.
    And the long overdue antenna replacement.. I do now have a better radio reception.
    #1691
    Mga Sir ask ko lang if you know a talyer na familiar sa APV natin in the area's of Taytay or Cainta. Maraming Salamat po
    Dec 2013
    #1692
    Hi guys. Question lang po bka alam nyo po problem ng suzuki apv str 2008 ko kc nmamatay po xa kpag heavy traffic. Pro phinga lang knti aandar na nman. Thanks po
    #1693
    ^ Many possibilities. Could be as simple as fouled spark plug/air cleaner. a failing ignition coil, or fuel contamination to injector problems. Have it diagnosed by a competent mechanic if you cant DIY check the basic items.
    Oct 2013
    #1694
    merry christmas po sa lahat..god bless!
    Dec 2012
    #1695
    Any recommended sellers of seat covers and floor mats for an APV GA ?
    Sent from my GT-N7100 using Tsikot Forums mobile app
    May 2007
    #1696
    *12vdc re: auxiliary fan. After 87+ kms, same problem as yours. How much is the replacement? Motor lang ba papalitan? Thanks.
    #1697
    Depends, if your fan blade went off or misaligned damaging the rad fins, that will surely add to the cost Mine is having some unusual noise during startup but not so loose to the point that it makes contact with the rad or vibrate.. Thinking of replacing it when the fan starts to wobble, seize, slow down, or die.. Bought the motor only as a reserve and its still in the stockroom..
    P7785 at Zuk Macapagal.
    #1698
    May 2007
    #1699
    Thanks for the reply 12vdc.
    Apr 2010
    #1700
    wow! OBD reader! :D
Suzuki APV [Merged Threads]
