Page 82 of 134 FirstFirst ... 327278798081828384858692132 ... LastLast
Results 1,621 to 1,640 of 2668
    Mar 2007
    #1621
    Hello to all. Its been years that I've revisited this thread.
    My 2005 GLX is already 8 years old and 95000km on the odo, and just had its PMS. I wasn't expecting what the mechanic recommended that the front shocks,brake pads & brake shoe had to be replaced. At the same time I had its alloy mags restored at promaster.
    How much it cost me....
    front shock (OEM) - 16,0000
    front brake pads (bendix) - 880
    rear brake shoe (bendix) - 1,800
    oil filter (OEM) - 385
    spark plugs - 540
    mag restoration - 4,800
    wheel fitting & balancing - 800
    oil change (semi-synthetic) - 2600
    labor - 3000
    My bill racked up over 25T, as the shocks took a big chunk of the bill. But I guess the shocks did serve me well. And perhaps my APV will stay with me for another 8 years.
    For the first time I'll be using Bendix brake components, as the OEM would have cost me 4 or 6 times more. I tried searching the same for the shocks but in vain. I had no choice but to take the expensive OEM shocks. But when I've bought the shocks, it had the name KAYABA stamped on it.
    Apr 2013
    #1622
    good day. question ko lang kung ano maganda pangtanggal ng scratch. sa tinggin ko yung scratch ay nasa base na. ano magandang gamitin? tnx
    #1623
    Hello
    Has anyone seen a G15A engine side by side with a Toyota 2C-T? I am wondering if a 2C Turbo would fit inside the engine bay without any major modification, just engine support modifications.
    #1624
    Quote Originally Posted by itlog ng dragon View Post
    good day sir,
    where is your casa where you replaced your radiator fan? I might have to replace it soon.
    thanks po.
    edwin
    I use pang Toyota Vios. Make sure you install the wire correctly. Kung surplus bibilin mo, make sure may harness wire na kasama.
    Only difference is laging hi ang motor fan kaya mas matagal ng akaunti ang pag akyat ng tempt/ Pero sa tingin mas malamig konti ang ac sa trafficc.
    Vios
    P500 to P800 surplus
    P1200 Replecament brand
    Labor. DIY
    Also Avanza brake pads can be use for our APV.
    #1625
    And to answer my question and for the reference na rin..
    Culprit was ignition coil (not far from what i suspected)
    Gave the job to casa (troubleshooting & t-belt replacement). And the worth of doin it with casa..
    Less the hassle and time of tinkering for me,so still worth it..hehe. Taga lang talaga casa labor.. I can replace ignition coil in 5minutes.
    Hi there.
    May I ask kung saang dealer ito?
    #1626
    ^ Zuk e-rod bro.
    Mas readily availalble parts sa kanila. Even Macapagal sakanila kumukuha parts.
    #1627
    ^ Zuk e-rod bro.
    Thanks, I might have mine change anytime this year.
    Apr 2013
    #1628
    hi, question lang tungkol sa aircon. pag unang bukas ko ng aircon may bad odor, pero pag makalipas na yung ilang minuto nawawala na yung bad odor. Tanong ko lang kung normal ba to sa apv? kung hindi paano matatanggal yung bad odor? tnx
    May 2012
    #1629
    same with our apv sir mabaho ung aircon lalo na pag tag ulan parang may nag moist tapos na kukulob ung amoy,,,solution po siguro strong air freshener or aircon filter..
    May 2012
    #1630
    Ganun din problema ko Jimny ko. Halos bago pa. Amoy trapo ang buga pag bukas ng aircon.
    Solution ko is to run the aircon on heater mode for a minute before I shut-off engine at the end of a trip. Thermostat pointing at 12 o'clock. Hoping matutuyo yung moisture sa aircon hoses.
    Malaki naman ang tulong. di na amoy trapo. no need to mask the smell with car freshner.
    Jun 2013
    #1631
    bro ung sa vitara na latest model mags 16" 5holes, PCD114 pwd sa apv yun?
    Apr 2010
    #1632
    Quote Originally Posted by apv2008enz View Post
    yes. we have 2 APVs that uses the new Vitarra Mags.
    #1633
    yun akin mga paps mag 2 years na pero amoy bago pa rin siguro dahil bihira ko gamitin.. pero may time na parang nagkaka amoy pero nawawala rin naman pag malamig na
    Sent from my GT-I9505 using Tapatalk 2
    #1634
    you may install an aircon filter using the suzuki swift aircon filter photo's posted here:
    kindly join Club Suzuki Philippines - Index
    just like installing an aircon filter to a non equipped aircon filter montero
    the site have solutions(pre solution) to most of your suzuki problem
    Aug 2013
    #1635
    last week my engine start to jerk once in a while but it stops after awhile. i experienced this before and the culprit was a spark plug.
    yesterday, i replaced all the spark plugs with new ones thinking that this may be the cause again. after replacing, the engine don't start anymore. i checked the high tension cable and the coils but they are properly working. Also, battery is good, there's enough fuel and engine oil, and checked all the fuses with no busted found. any idea what other parts to check to solve this problem? appreciate your suggestions on this. thanks.
    #1636
    Quote Originally Posted by Bench_93 View Post
    ah simple o2 sensor replacement, but expensive good luck
    Aug 2013
    #1637
    but the engine trouble light indicator is not lit. ilan ba ang o2 sensor?
    May 2012
    #1638
    isa lang po "o2" sensor ng apv(ung naka kabit sa bahay ng filter element natin)(kung sira po un or mali ang lagay dapat may ilaw na engine check sa panel gauge natin)...pero kung sensor lang sagana ang apv jan..throttle position sensor etc...
    May 2012
    #1639
    sir pano po bang ayaw mag start??? as in wala talagang redondo??? or ayaw lang tumuloy ng start??
    Aug 2013
    #1640
    may redondo, ayaw lang tumuloy magstart. pina-check ko sa talyer kahapon at sabi nila baka yung MAP sensor ang problema.
Suzuki APV [Merged Threads]
