^ Madali lang sir, kahit nga siguro walang tools kaya ng kuko. Mas mahirap pa angatin ang upuan para silipin ang oil level, pramis.![]()
this is what P8300 can buy in indonesia...
all original:
apv engine support left, right and rear
apv brake pads
apv radiator fan motor
apv thermostat
apv shock boots
vitara tensioner bearing
vitara brake pads
Hello JonJon,
After my feebie PMS (60,000 KM) I do my succeeding PMS at Speedyfix. However, I do go back to Suzuki for serious auto jobs, with my auto tranny pan and gasket replacements. (2012)
Back in 2010, I serviced it at Denso for aircon jobs, replaced the condenser, spending 21K in the process.
Hello po mga Sir ! Good Day po! I would just like to ask a few questions dahil due na din ang apv ko for maintenance. Im running at 80k now and magppa major pms na po ako. Ayoko po sa casa magpagawa dahil meron po akong reliable mechanic. ;)
Anyway po, as ko lang san pwede makabili ng drive belts for our APV? sa Banawe po maraming nagbebenta kaso di ko sure alin ung bbilhin. Kinda noob on this po. sorry... hehe..
2 drive belts po sana.. and how much po kaya aabutin neto? and another question, pwede po ba na hindi na mag engine flush kung magpapalit ng engine oil from 10w-40 to full synthetic na 5w-30 or 5w-40?
Thanks po! ^_^
For your mechanic
Fan Belt (A/C & P/S) - OE 95141-61J10, Replacement 4PK1050
Fan Belt (Water Pump & Alternator) - OE 17521-86500, Replacement 4PK815
Idler Pulley Bearing (A/C & P/S) - NSK/ 6301 DU2
No idea with current price but they are cheap and available everywhere.
Flush not necessary. Personally i dont recommended FS for hi mileage engines, not unless you have been using FS from the very start of your OCI. Stick to SS or mineral and 5k kms OCI.
Any recommendation for a tire brand and a store? Need to replace all four. Should I stick with 6ply or go 8ply? Checked with a Yokohama shop, S&R, Goodyear, and some sellers from olx.
Posted via Tsikot Mobile App
^ Go with 8Ply, price difference bet 6ply and Duraplus 4Ply is almost the same.
TOYO TYH08 185/R14 102 S A/T, 8-Ply, Tubeless
Bought it last year for P3.6k ea at Sta Cruz
Anong battery recommended niyo for our apv? Need ko na ata ireplace tong stock batt kasi 4 times na siyang ayaw mag start at kailangan itulak para umandar. I'm rooting for motolite champion low maintenance battery kasi mas mura pag LM kaysa FM e. Ano size ba ng battery natin and how much? Thank you!
Ang recommended batt po dito sa tsikot is amaron battery sir
As per my experience in fleet, nagkakaroon ng sealing probs kung biglaang shift. Im not sure if it has something to do with FS having smaller and uniform molecules. Pwede naman po FS kung FS na gamit from the start. Maybe its just me, you can try it and see for yourself baka iba ang outcome.
When will be the right time to replace my front wheel bearings? My ride is almost 9yrs old and 100K km on the odo.
Wheelbearings are supposed to be maintenance-free. Replace only when they get busted.
Front i think is sealed type, no maintenance required
Rear i believe is tapered just like any live axle setup, it can be repacked but usually not necessary if you don't do much hub-heigh water driving that dries away and leave contaminants in the bearing lubricant.
12VDC,
Thanks for the tip. Seems I shouldn't have bought the bearing too soon. Ibenta ko sa suit.
BTW, maybe too late to tell you, but the APV's ODB port won't work with Scangauge or its clones and ODB dongles. I asked Migs of Speedfix, who has Scangauge, to test it but it failed.
I have a Bluetooth dongle that attached to my 2011 Ford Escape that work well, but not for the APV. Maybe my 2005 ride's ECU is too old or just not compatible with the gizmo.
