Results 1 to 10 of 21
- Jan 2019
- 20
February 11th, 2019 02:30 PM #1Mga kaTsikot ayos na.
Ang nang yari pala naglock yung left wheel ko kaya nagshake yung steering wheel ang ginawa pinalitan nang Rotors, Brake hose, Brake Fluid at Brake Pad okay na sya worn out na din kasi kaya pinalitan na.
Then sa matigas na Steering wheel may niluwagan at hinigpitan lang.
Umabot nang 18K lahat lahat.
Wheel Aligntment nang Yokohama is hunter.
Case closed
- Mar 2019
- 6
March 2nd, 2019 11:31 AM #3hi, can you recommend po any auto shop near kalayaan makati? tie rod replacement. tried google pero along buendia/vito cruz na yung pinakamalapit. kinakabahan kasi ako baka biglang magbreak na siya if ibabyahe ko pa ng medyo malayo. thanks!
- Sep 2018
- 46
June 23rd, 2019 04:09 PM #4hi ma ka tsikot,
may experience din ako dito steering wheel shake, when i reach ~ 90 kph.. pinacheck ko recently, and ganito nila chineck yung auto ko.
- rev up the engine, other guy check the engine mounts. - clear
- jacked up, held the wheel on 3-9 and 6-12 oclock position, may play both front wheels.
as per mechanic, eto yung need replacement. hingi lang ako ng advise if all of these needs to be replaced.. this would cost around 16k kase.. thanks.
2 PCS RACK END - 3800
2 PCS TIE ROD END - 2800
2 PCS CV JOINT - 4300
2 PCS TIRE BALANCING - 600
CAMBER - 1950
LABOR - 600
June 23rd, 2019 04:15 PM #5
- Jan 2008
- 4,726
June 23rd, 2019 06:36 PM #6
- Sep 2018
- 46
June 23rd, 2019 08:12 PM #7
June 23rd, 2019 09:02 PM #8
Turbo timer yung feature na yan sa Everest? Sana default feature yan sa mga naka turbo na sasakyan.
0dometer problem
