Results 1 to 10 of 17
June 28th, 2008 10:04 AM #1
mga gurus tanong lang, pag nag steer kasi ako ng sagad na going to right may squeeking sound(i dont know the right term) ako naririnig, and i noticed na basa yung hose connected sa power steering tank, pero hindi naman nababawasan yung power steering fluid ko. connected kaya yung squeeking sound na yun dun? o may iba pa kayo idea? what might be the problem? and how much kaya ang cost nito, para pag nagpagawa ako may naka ready na ako cash.. TIA
June 28th, 2008 09:25 PM #2
sir baka sa fambelt mo karamihan kasi ng car ganun pag sagad ang steer kung hindi lalangitgit e bumababa ang rpm
kung hindi pa naman dapat palitan at maiiwasan iliko ng todo diba??
para mas makatipid
June 29th, 2008 02:01 AM #3
You said, SAGAD na kabig?
If you steer your wheel lock to lock natural ang power steering ay iingay dahil you have reach the maximum turning radius ng sasakyan mo.
At yong basa sa hose next to the power steering reservoir maaring over fill ang reservoir mo. Punasan mo yong hose and the reservoir drive it for awhile then trace with your finger kung saan galing ang leak. Kapag ang power steering nag-iingay kahit kunting kabig, "bleed it" or check the belt might need to adjust.
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 29th, 2008 04:38 PM #4ps hoses na orig tend to be expensive kahit na maikli lang. short hoses will run mga 5-600 where longer ones can be 1-2000 depending on the car.
June 30th, 2008 05:18 PM #5
sir, bago na fanbelt ko sinabay ko na dati nung nagpalit ako ng timing belt.
yes sir sagad as in lock to lock, pag going to right lang naman may squeeking sound pero pag going to left na sagad wala naman. pag lumiliko ako sa right na hindi ko sinasagad ayos lang walang problema walang ingay, pero pag na reached nya na yung pinaka dulo yung hindi mo na maiikot dun na umiingay mawawala lang yung ingay pag kinabig mo na pa kaliwa.
wala naman ingay ang power steering ko kahit konting kabig, as i mention above pag pinaka sagad lang going to right.
maybe one of these days dalhin ko na lang po sa shop nyo pag hindi na busy.
Thank you mga sir for the inputs, naghihinayang kasi ako sa gastos mukhang ok pa naman ata yung hose ko kasi di naman nagbabawas ng power steering fluid. ang concern ko lang talaga yung ingay na naririnig ko. kung dun yung problema, talagang kelangan ko nga palitan.
- Nov 2003
- 3,849
- Jan 2007
- 137
August 15th, 2008 10:54 PM #7mga sir, un hose ng power steering ko may leak, magkano kaya ang magagastos pag pinagawa ito. may maliit na circle yun location ng leak malapit (1cm) sa "joint". puede kaya cut lang then connect ulit sa joint ?
August 16th, 2008 11:18 AM #8
THE AUTO SPECIALIST
- Mar 2006
- 607
August 16th, 2008 11:42 AM #9replace mo na lang siguro baka mura lang yan
sa tingin ko return hose lang 'to
August 20th, 2008 10:51 PM #10
baka kulangin yun gamit mo pag DIY. pwede mo ipagawa sa mga gumgawa ng hydraulic hose.
Xiaomi E-Car
