Results 11 to 17 of 17
August 22nd, 2008 12:07 AM #11
ganyan ganyan din ang butas ng sentra (2000 STA) ko just today....
pahalng ang butas na parang hiniwa ng blade na maliit... sa tabi din ng joint. kapapacheck up ko lang sa casa 2 weeks ago,
baka kaya binutasan sa casa... ???
- Jan 2007
- 137
August 22nd, 2008 02:57 PM #12thank you sa mga reply, hanap muna ako ng replacement hose at magaling gumawa.
- Jan 2008
- 4,726
August 22nd, 2008 06:24 PM #13dalhin mo lang yung hose mo sa mga "power steering hose" shops.. they have the proper hose and fittings for your ride... also they have the right tools needed as you cannot DIY the hose repair.. your hose is CRIMPED and uses high quality hose since power steering operates under high pressure.. repair will cost 1k up.. oem hose cost around 4k to 5k...
it is normal in the first use of the brandnew hose your will hear vibration sound (ugong) but that is just caused of the brandnew hose.. once it bends naturally the sound will go away...
also it is normal that when you turn the steering all the way on any direction, you will hear vibration sound since the pump is struggling to give pressure to your rack and pinion eventhough the steering is in full turn, this can damage your power steering system...you should turn the steering wheel back a little to relieve the pressure.. It is clearly written on your owners manual (if you have) i suggest you read it..
August 25th, 2008 06:40 PM #14
- Jan 2007
- 137
September 10th, 2008 09:45 AM #15nagawa na rin sa wakas un power steering hose ng car ko,
dinala ko sa "power steering hose shop" then crimp lang nila un hose (less than 30 mins) then kabit doon sa kotse (mazda 323 familia).....
new hose + crimping - 1,225.00
labor + ATF Fluid - 600.00
TOTAL = 1,825.00
heto naman un estimate sa ZAFRA
hose "replacement" - 4,200.00
labor - 750.00
TOTAL = 4,950.00 (di pa kasama ATF dito )
pag orig daw - 7,800.00
Nagtanong naman sa iba :
Original Power Steering Hose sa Pasay Rotonda - 4,500.00
pag bumigay ulit, palitan ko na ng original..hehehe !
- Jan 2008
- 4,726
September 10th, 2008 10:04 AM #16hindi na bibigay yan basta basta... pinapalitan mo ba yung fittings?? kasi baka yung ang sumunod na masira...
wag mo kasi ililiko ng sagad yung manibela mo para hindi mag build-up ng high pressure yung system.. kapag nag turn ka ng sagad (u-turn) ibalik mo ng konti (mga 1inch turn back) yung manibela para ma-relieve yung pressure
- Jan 2007
- 137
September 10th, 2008 03:05 PM #17ganyan nga sir ginagawa ko pag-sumagad ang kabig bawi agad ( un din ang sabi ng manual). un fitting ba sir ang pinagkakapitan ng hose ? pinalitan din un, magkabilang dulo. tama ka sir, pagnakapihit ng todo, doon mo lang maririnig ang ugong pero pag binalik ng konti wala naman.
thanks !
The 1.5G is good enough for me tbh My current car doesnt even have a rear camera and Ive never...
All New Toyota Corolla Cross
