Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    #21
    Quote Originally Posted by Vodka View Post
    pinoys would call it the tata u-nano would fail for the same reason it failed in india, pinoys wouldn't want to be seen driving a "cheap" car they'd rather buy a used car instead
    speaking of spresso i think i wanna check it out later at a local dealership...
    personally,
    i wouldn't mind being seen driving a cheap car.
    as long as i fit comfortably inside, it is airconed, and it is not a gas guzzler.
    in the workplace, "everybody drives a not-cheap car. it's actually hip, to be driving a much cheaper car". wag lang yung kinakalawang na tetanus-carrier at tumutulo ang bubong at sahig.. heh heh.
    Feb 2014
    #22
    personally,
    yeah me too. i think i even wanna buy a bajaj RE to play with
    another major issue w/ the nano is the very poor safety
    #23
    Surface must be oil/grease free. Using something like the Bailcast split CV Boot glue might be better.
    Universal CV Boots
    triton or toyorama then exalta for labor in banawe ...
    cheaper, faster and cleaner [emoji28]
    Jun 2013
    #24
    Out of boredom, I decided to just wrap the damn thing in a flexible self-fusing rubber tape in order to prevent water from going in. Who knows what this band aid solution does, but it's better than nothing I guess.
    #25
    "for temporary use only."
    eventually, we all know, it will have to be replaced by the appropriate replacement part.
    pantawid covid lang.
    May 2011
    #26
    If replacement of the ball joint is not feasible at the time, i would clean the area specially the boot with carburetor cleaner or lacquer thinner. Then i would seal the ripped boot using ultra black silicone rtv sealant or use np1 adhesive/sealant. It will be almost as good as the oreeeginal boot
    Aug 2020
    #27
    replace sir, kakapalit ko lang ng boot, sabi kasi ng mekaniko ko, mas mainam daw palitan na para hndi pasukan ng dumi
    Apr 2005
    #28
    My car's axle boot is leaking and the mechanic recommended to replace all (inner and outer). Kasi daw malamang susunod na rin yung ibang boot. Should I follow his advice? Or isa lang yung sira ang papalitan?
    Feb 2024
    #29
    When was the last time you changed them? If it's been a while, I suggest following your mechanic's advice.
    #30
    kung hindi naman masyado mahal,
    replace na all, po.
    save yourself the downtime and effort.
    If more than 5 years na din, palitan mo na. Susunod na din talaga yan sooner than later.
    Apr 2005
    #32
    ^Thanks for the advise guys. Already replaced all.
Rubber boot question (repair or replace)
