Results 1 to 10 of 25
- Apr 2017
- 35
October 12th, 2019 05:12 PM #1Mga sir, sino na naka experience sainyo nito? Bago ung shock ko sa unahan, kyb ung brand nyayon na naikabit na may langitngit. Toyota innova nga pala ung sasakyan ko. Nung dinala ko sa isang shop ang gnawa hinigpitan at nilagyan ng oil hndi binaklas, nawala sandali ngayon meron nnmang langitngit. Help naman po salamat.
- Jun 2005
- 3,774
October 12th, 2019 06:30 PM #2
October 12th, 2019 08:44 PM #3
normally the front shocks last longer than the rear. but by the time it fails or needing replacement. the bushings of the lower arm also fail and the shock mounts too on top. set dapat pag mag palit in my opinion.
- Apr 2017
- 35
October 13th, 2019 05:46 AM #4
- Apr 2017
- 35
October 13th, 2019 05:49 AM #5sir sa taas po galing ung langitngit eh? nagpalit kasi ako ng shocks akala ko kasi nag li leak na eh hndi pa naman pala eh nakabili na ako so ipinalagay ko na. Bago ako magpalit ng shocks walang langitngit or ano pa mang ingay, nagsisisi tuloy ako, kung di ako magpalit ng shock mounts makukuha ba to kung ga grasahan lng ung mga bushings? Ung ka trabaho ko kasi innova din ang kotse nya nung nagpalit sya ng shocks wala naman syang napansin na ingay tnanong ko kung ano ginawa nya, yun sbe nya ginrasahan lng daw ung mga bushings nung kinabit.
- Aug 2017
- 319
October 13th, 2019 09:10 AM #6
- Jan 2008
- 4,726
October 13th, 2019 09:14 AM #7
- Apr 2017
- 35
October 13th, 2019 09:18 AM #8
- Aug 2017
- 319
October 13th, 2019 09:19 AM #9See? Hindi sira shocks pero pinalitan mo.
I had a squeak, I used a camera probe to check, I saw the shock mount torn, I pulled it down... Checked the shock absorbers, also worn... I checked the stabilizers, also worn.
So, I replaced the shock mount, shock absorber stabilizers... All in pairs.
No more squeak. Just because I checked first.
Do not fix what is not broken
- Apr 2017
- 35
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
