Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
    May 2005
    #31
    pagmabagal, i.e. speeds below 80kph, wala namang ugong o vibration of any kind. at these speeds smooth ang takbo kaya medyo nalilito na ako kasi sabi ng isang shop, gulong lang daw tapos sabi naman ng isa pang shop, bearing daw
    what's the best way to know for sure :question:
    dapat sundin nyo ang advice ni sir afrasay .lift nyo ang mga tires nyo .at kalugin nyo (hawakan sa upper at lower part ang tire ,HINDI alugin ng pakaliwa or pakanan ) kung may alog ..may tama na ang wheel bearing nyo
    Jul 2004
    #32
    Quote Originally Posted by BoEinG_747 View Post
    thanks sa advise. ipa-lift ko nga at ma check
    Jul 2012
    #33
    Need na ba ASAP palitan if wheel bearings nga? wala pa budget eh
    #34
    Quote Originally Posted by nashimoto View Post
    Pwede naman delay ng sandali basta ok Lang sayo maingay, hinde naman mahal magpapalit Sigurd nasa 3k+ lang plait parts and labor na with press in and out Sa machine shop
    May 2009
    #35
    sa experience ko as a DIY mechanic, the more na pinapatagal mo dumarami ang sira. worst case, hindi lang fatal sa sasakyan kundi pati rin sa occupants ng sasakyan.
    imo, palitan mo na yan. mura lang naman yan kung front bearings. mas mahal kung rear axle dahil kelangan mo pa ng hydraulic press para sa removal & replacement ng wheel bearing. kung pinatagal mo pa yan, may possibility na maputol ang axle (kung rear drive iyan) or spindle. kung hinde magbebend iyan. either way palit ng axle or spindle iyan.
    well, kung ayaw mo. follow shadow's advice na lang.
    #36
    make and model then harap or likod?
    #37
    Jul 2012
    #38
    honda jazz 2005 - likod yung maingay
    #39
    depends.... pag nadurog ang bearings, di na iikot ang gulong... ma stuck up ka.
    #40
real wheel bearing, kelang palit
