Page 2 of 2 FirstFirst 12
Results 21 to 40 of 50
  1. FrankDrebin Guest
    Oke lang. Nasa body repair pa yung ipapagawa. Text na lang kita. Try kong makakuha ng exotic na pulutan.
    Mar 2003
    sir ungas pag nagpa repack po ba papalitan narin ang 4 axle boots sa harap? meron po ba additionla work pag 4x4 compared to rear drive auv? tama ba intindi ko drive wheels lang ang may bearing.
    PROMDIBOY::: Pwede mo na rin isabay ang axle boots kung may sira na ito. Subukan mong kurutin ang goma kung malutong na. Meron additional parts or work involved, but not that much to be concerned about. Front ends of rear wheel drive vehicles have bearings too, usually hiwalay ito at two types of bearings are used. And pagkakaiba lang ng 4x2 sa 4x4 ay mas malalaki ang bearings na ginagamit sa front end. It has to make space for the axle upfront, compared to 4x2 units which is only used for steering purposes and does not have axle.
    Mar 2003
    thanks sir ungas.
    May mga telltale signs naman bago bumigay ang bearings like humming sound (ugong) harsh (magaspang) na tunog and worst mag stuck/seize yun tires (pede ka parin maka uwi once lumamig na ang bearings). yun rear axle bearings hindi ni-rerepack kasi usually palit agad. kailangan din ng oil seal pag nagpapalit ng front and rear bearings.
    Si ferdie gumagawa niyan. may malapit na machine shop sa kanila.
    Ungas:::reserve mo ako ng front bearing don't forget.
    Ferrari::: :D
    Jul 2004
    Quote Originally Posted by afrasay View Post
    May mga telltale signs naman bago bumigay ang bearings like humming sound (ugong) harsh (magaspang) na tunog and worst mag stuck/seize yun tires (pede ka parin maka uwi once lumamig na ang bearings)................
    :question: kung ang humming sound (vibration or ugong) occurs only when the speed is between 85kph to 100kph at nawawala from 100kph and above, is this is a symptom of a bearing problem or is this a tire problem?
    Yup. Yun bearing kahit mabagal madidinig mo yun ugong. lumalakas ito habang bumibilis ang takbo. pede mo rin pa check by lifting the tire and checking kung may kalog na.
    Jul 2004
    pagmabagal, i.e. speeds below 80kph, wala namang ugong o vibration of any kind. at these speeds smooth ang takbo kaya medyo nalilito na ako kasi sabi ng isang shop, gulong lang daw tapos sabi naman ng isa pang shop, bearing daw
    what's the best way to know for sure :question:
    May 2005
    dapat sundin nyo ang advice ni sir afrasay .lift nyo ang mga tires nyo .at kalugin nyo (hawakan sa upper at lower part ang tire ,HINDI alugin ng pakaliwa or pakanan ) kung may alog ..may tama na ang wheel bearing nyo
    I have complete set of bearings for a Patrol, 2 fronts and 2 rears.
    goody
    OT:::si FRT di daw makakapunta mamya. BDay ng misis niya. So as Nelson- studies. tagal ng 2pm.
    If pareho Lang sa wheel bearing ng Jazz mo Sa mga FD, sobrang bilis Lang Palitan yan hinde na kailangan ng machine shop pressing. Palit buo pati hub. Wala pa sigurong Isang oras
    I would say Palitan mo na dalawang side
    tama dapat dalawang side kasi hahabol din yung isa kaagad.
real wheel bearing, kelang palit
