Results 41 to 50 of 58
- Sep 2014
- 12
September 29th, 2014 03:32 PM #41One more thing po, I've noticed na mabula yung fluid inside the reservoir. Parang softdrinks.
- Aug 2012
- 2,767
September 29th, 2014 04:31 PM #42Air bubbles in the reservoir
- Check for crushed inlet hose or a loose hose clamp allowing air into the suction side of the system.
- Check for cracks in reservoir
Pump
- Front seal leaking > Replace front seal
- Pump housing leaks at either end > Replace the housing O-rings. If the housing still leaks, replace the pump.
Pump outlet hose (High-pressure)
- Leaking at the threaded fitting > Tighten the fitting. If it's still leaking, replace the O-ring or pump outlet hose.
- Leaking at the swaged point > Replace the pump outlet hose
Pump inlet hose (Low-pressure)
- Leaking because of damage, deterioration of improper assembly > Replace or repair as necessary
September 29th, 2014 05:30 PM #43
ako din napnsin ko din na parang may bula din tapos sa semento yung patak nya ganun din may parang bula din lalo na pag medyo elevated pababa ang parada dami tagas pag flat surface di naman ganun kadami patak
- Sep 2014
- 12
September 30th, 2014 12:46 PM #44*red_one
Thanks for the help. I called Mang Toto and he said it's the PS pump that needs to be replaced. Another whooping 9,000 for the surplus lang. Anyone knows where to get a cheaper part? Also, is mang Toto really that reliable? :-(
Posted via Tsikot Mobile App
- Sep 2014
- 12
September 30th, 2014 12:48 PM #45If I may add, sabi nung mechanic in our area, pump na nga daw talaga kasi puro gasgas na daw. Ganun ba talaga yun? Pag gasgas need palitan?
- Aug 2012
- 2,767
September 30th, 2014 04:26 PM #46
- Aug 2012
- 2,767
September 30th, 2014 04:28 PM #47
September 30th, 2014 08:17 PM #48
Pano nya nalaman na gasgas? Pinabaklas mo ba yung pump?
I could be wrong pero baka nga pump talaga problem ng crv mo may way para ma test yung pump mo kaso kakalasin yan eh.ikot ka sa banawe baka makahanp ka ng mas mura pa pero make sure na yan Talaga sira baka kc kaya pa irepair yna kung oring lng mga sira.
Registered User
- Mar 2011
- 276
September 30th, 2014 10:01 PM #49Na experience ko dati na pag nag add ka different brand na PS fluid or atf, mag bubbles sya.
September 30th, 2014 10:31 PM #50
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
