Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    May 2009
    Tagal ko nang naghahanap neto.
    any leads kung san makakabili neto?
    ang hanap ko actually is the 3M silicone paste (hindi oil ha) or any good brand of a brake grease....
    i had no choice up to now but to use the regular petro based bearing grease. ang problema netong regular na grease e natutuyo sa katagalan at nabubulok ang rubber parts (caliper pin boot)...
    Aug 2012
    meron for sale na Silicone Dielectric Grease sa OLX. P2,500 for 400ml can. search mo si "crystalmarizlee" (Spanjaard Products).
    for small electrical parts or connectors (sensor boots, spark plug boots, etc.) pwede rin gamitin ang Silicone Grease for Flashlights. search mo "Nitecore SG7 Silicone Grease", "Nextorch Silicone Grease" and "Ikelite Silicone Grease". P250 or P300 each sa OLX.
    another seller of Silicone Grease is "1128732012" (Aeons).
    Meron sa concorde cyclo, p200+ if im not mistaken nasa tube parang toothpaste. I'm using it to lubricate brake and rubber/plastic components.
    Posted via Tsikot Mobile App
    Aug 2012
    yup, nasa tube na parang toothpaste kapag small quantity.
    May 2009
    Concorde megamall ba iyan brader? makapunta nga jan minsan. salamat sa info...
    may mga nabasa ako re: dielectriic grease. di rin advisable gamitin sabi. pati antiseize. so stick to silicon grease for brakes. yan din ang advise ni ETCG.
    Aug 2012
    ang alam ko silicone grease is same as dielectric grease..
    Aug 2012
    anti-seize compound is different. this is used for screws/bolts and connections between unlike metals to prevent seizing or lock-up.
    May 2009
    well then papakyawin ko na lang yung dielectric at silicone grease na makita ko. hehehehe
    salamat sa info
    Jul 2006
    This.
    Available at Wuerth Philippines.
    Photo borrowed from the internet.
    May 2009
    This.
    yan ang the best...
    kaso san bang tindahan meron nyan? halos brake cleaner pa lang nila ang nakikita ko sa mga auto supply. lalu na kung probinsya.....
    siguro kelangan din imarket sa mga shops, auto supply, mechanics, etc. yung importance ng product na ito.
    the reason kung bakit ako ay muling naghahanap neto dahil sa nangyari sa pickup ng pinsan ko. pinakita sakin ang mga sira. gastado na mga caliper pin boots. 2 years ago kumawala yung brake caliper nya due to looseness in the caliper guide pin. as in hose na lang ang kumakapit. somehow connected din yung paggamit ng regular petroleum based grease.
    Quote Originally Posted by miked View Post
    Sa NorthEdsa yata may nakita ako newly delivered or baka meron na rin sa lahat ng branches, nagkakaubusan kasi nyan lagi.
    Im not sure kung pede mo ito substitute, pero palagay ko sa non-heating parts ay pwede. Pang re-pack ng clutch fan, mas tacky lang ng konti yung cyclo.
    For contact parts like brake shims, eto pwede gamitin copper grease.
    Meron din sa Workstation Hardware Mart(search na lang kung saan meron sa Pasay at Harrison), tin can bottle na may brush pareho for hi-temp application
    Permatex 09128 - Copper Anti-Seize Lubricant
    Permatex 77124 - Nickel Anti-Seize Lubricant
    For bearing repack. Tested ok ito sa rubber pero still not recommended since synthetic petrochem based pa rin.
    Aug 2012
    *12vdc: magkano bili mo sa cyclo silicone compound (150g) at cyclo dielectric grease (14g)?
    Cyclo C-705 Silicone Compound P699.75
    Cyclo C-710 Dialectric Grease P179.75
    Tetrosyl CC XCG070 Copper Grease P199.75
    Permatex 09128 Copper Anti-Seize Lubricant P485
    Permatex 77124 Nickel Anti-Seize Lubricant P775
    SKF LGHP 2/1 Polyurea 1kg - P2276
    Denso Silicone Oil 046964-0010 - P149.75
    That was 2-3years ago
    May 2009
    nagkakaubusan ba lagi? mukhang ikaw lang ata nanghohorde ng supply e. ....nakabili ako last time ng copper grease. nasa P200 nga iyong isang tube...kaso diko na mahanap kung san lupalop nagpunta.
    Aug 2012
    *12vdc: thanks. sana ganyan pa rin price now.
    Bought some diesel stickers for my diesel mpv at concorde, esem Arroceros..
    Ayun o, may apat pa..haha.. Hindi ko binili, madami pa ako stock.
    Wala rin sa True Value Shangrila. Pero marami daw naghahanap. Halatang sinagasaan nyo mga baha hehe.
    May 2009
    1 lang kinuha ko kanina sa gamol....bale may isa pa dun. saka nako magiimbak..nakakahiya naman sa ibang nangangailangan. hehehe....joke lang. may kelangan pa kasing gamit na dapat bilhin.
    [IMG][/IMG]
    May 2009
    marami naghahanap? e mukhang isa lang kumuha e. hehe
    May 2009
    uy less 10% pala dun sa silicone grease kanina sa gamol...less 5% naman dun sa copper grease
Brake part lubricant/grease
