Results 11 to 20 of 58
November 22nd, 2002 12:45 AM #11
My mechanic's address is 3516 J. Lukban St. Bo. Obrero, Manila. He's name is Ferdie. May nakita ako sa 4x4 magazine, they call it RAM system. Pinapalitan nila yun gear box and pump together with they tear drop fluid container. They say you can still turn tires in places (ea. between boulders), that your usual system can't.
- Nov 2002
- 208
November 22nd, 2002 10:51 PM #12OTEP/AFRASAY,
Thanks for your advice...
UNGAS: I had the hoses checked wala naman leaks. Malinis. Tingin ko nga tama si afrasay sa convertion malamang.
Many were suggesting since it is converted palitan ko raw yun gearbox if bleeding fails. Nagtry nga ako maghanap sa atco lang meron.
What do you guys thinks.
Thanks :lol:
- Nov 2002
- 208
November 23rd, 2002 01:38 PM #14Afrasay,
Do you mean pwede linisin and overhaul yun gearbox? Pasensy na for my ignorance regarding this issue :oops:
So do you suggest,ipa overhaul ko muna the whole power steering? Meaning ibleed then ibaba para malinis?
Thanks a lot
November 23rd, 2002 02:06 PM #15
lancelot,
Dapat mauna ang overhaul/cleaning bago ang bleeding if ever you are planning on doing an overhaul. Siyempre if you bleed tapos ibinaba mo, then you have to rebleed upon reinstillation. Basically ibababa ang gearbox and bubuksan to check and correct any problems.
November 27th, 2005 09:42 PM #17
lancelot, palagay ko si Joseph (multinational) lang ang katapat niyan.
November 28th, 2005 11:43 AM #18
try mo to rev a little when turning during parking, looks like kulang sa pressure.
- Nov 2009
- 1
November 30th, 2009 12:33 AM #19[SIZE=2]Mga sir,
Patulong lang po. Last night as I was parking my car, I had difficulty in steering the wheel. Halos kapirasong kabig lang sa kanan o kaliwa eh parang nakasagad na... para bang nag-lock pero magaan pa din... yun nga lang hindi maikabig ng todo, parang few inches lang napipihit eh sagad na... i checked the fluid po eh okay naman pati yung belt... after several hours, biglang okay na ulit. ano po kayang possible na problem yun, and suggest naman po ng pwedeng gawin pag naulit... or suggest na din po ng PS specialist.
Salamat po ng madami!
[/SIZE]
- Jun 2009
- 1
January 27th, 2014 12:30 PM #20
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
