Results 11 to 18 of 18
December 15th, 2016 04:41 PM #11
Yung mga mahilig magcarwash after using the car, prone to warping of the disc brakes din diba?
UK forums madalas ko makita EBC nga. But was thinking baka mahal shipping charges
- Oct 2015
- 1,054
December 15th, 2016 04:58 PM #12If I recall correctly I bought the pads from DCPerformance along with my Koni shocks. Shipping was relatively cheap as I used a balikbayan box consolidator. Mura din lang siguro kung pads lang, liit lang naman nito.
December 15th, 2016 05:00 PM #13
^CB, that is possible (yung mga trip na magpausok ng rotors
); in my case i always cool em down or avoid hitting the rims or rotors if i hose down the car after driving in the rain.
It's really more of the quality i'd surmise. My Gen 10 Altis didn't have the problem (my driving habits and conditions are consistent).
December 15th, 2016 05:08 PM #14
- Oct 2015
- 1,054
December 15th, 2016 09:30 PM #15To quote a tuner friend, "kung magpapalit ka rin lang, palitan mo na ng maganda." I just hope DBA doesn't just rebadge Chinese blanks for their entry level offerings.
The reason why I got the Konis was the adjustable rebound damping. Adjustment is cumbersome but aside from that I can't complain. Ride is great when paired with medium duty OME springs. Well worth the money IMO👍
BANNED BANNED BANNED
- Jun 2007
- 122
December 16th, 2016 03:53 AM #16May Brake Drag Reduction Clip/Spring ba yan?
Palaging nakalapat yung brake pad sa rotor pag wala nun. Yung rubber boot lang kasi nagtutulak sa pad pag release mo ng brake pedal. Pag luma or expired na brake fluid pag traffic at uminit na fluid di rin mag reretract brake pad kahit pa may spring. Semi Metallic pati ang friction material ng Brembo. Parang ginto ang price ng rotor at caliper pag Brembo.
Make sure na within specification ang Lateral runout kung hub assembly yan. Kung wheel bearing palitan mo rin. Make sure na may Torque Wrench, Dial Indicator at Micrometer yung mag-iinstall para masiguradong within specs yung mga parts before nila install. Napadami kasi jan na napakagaling magdahilan. Yung manufacturer ng parts ang sisisihin sa kapalpakan nila. Nagkalat kasi nationwide ang shop ng mga SIRAniko. Pa wheel alignment mo sa dealership pagka install para mareset yung mga sensor ng stability control.
OK yung quality ng EBC rotor & pad sa F150, chamfered yung slot walang kanto. Medyo maarte nga lang sa brake pad.
- Jun 2007
- 122
December 16th, 2016 05:01 AM #17Oo na hindi, pag sobrang dami ng grease nawawash out at na cocontaminate yung pad at rotor. Mas una lang napupudpod yung part na di contaminated ng grease or brake fluid. Hindi naman talaga nawawarp ang rotor. Pwede ka naman gumamit ng DRY Lubricant katulad ng MoS2 na di nawawash out at di nag-aattract ng dust instead of grease. Ang problema nga lang sa MoS2 pag nalagyan yung rotor baka kahit irephase ang rotor di yon maalis.
- Oct 2015
- 1,054
December 16th, 2016 10:08 AM #18Honestly di ko pa nasilip ng baklas yung brake assembly sa harap. Pag salat lang sa center part ng rotor ramdam na yung bulge sa gitna. Last time nabaklas ito pinareface lang yung rotor. Will check that spring kung meron. Hub bearings ito, di pa nagpapalit since new. Baka nga palitin na din. Thanks for the tip!
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
