Results 1 to 10 of 11
    hi guys... ask ko lang if may significant improvement (or increase in height, better ride) if i put rubber spacers sa spring ko? i switched to 17" mags kasi, sumasabit na ung tires sa pang ilalim... ok na ba alternative ung spacers compared sa palit ng spring mismo? tnx
    Quote Originally Posted by exsior1111 View Post
    Rubber spacers will not change the ride quality of your car's suspension.
    As for alternatives, there is none that compares to the affordability of rubber spacers.
    noted on that. but will the spacer lessen or minimize ung mga time na sumasabit ung tires? will it increase height?
    thanks
    thanks
    Well, the rubber "lifter" will increase the suspension height by the thickness of the spacer. It would help minimize the rubbing of your tires against the fender.
    One method used to minimize tire rubbing is to have the fender lip "rolled". It is effective if you only need a minimal amount of added clearance. SPEEDLAB has the proper tool to roll your fenders.
    Aug 2004
    It'll depend on why it's rubbing. If it's rubbing because it's too wide, it'll help a little... but if it's rubbing because it's too low, it'll help a lot. Rolling the fender is a more complete solution.
    I had to do both with my car. Mags were too wide and car was too low.
    thanks guys. its rubbing bcoz its too low i think... ill go with the spacer first then drive if i need more, fender rolling is next... thanks
    appreciate more inputs
rubber spacers (sa spring) is it advisable?
