Results 1 to 10 of 11
- Mar 2010
- 19
March 11th, 2010 01:35 PM #1hi guys... ask ko lang if may significant improvement (or increase in height, better ride) if i put rubber spacers sa spring ko? i switched to 17" mags kasi, sumasabit na ung tires sa pang ilalim... ok na ba alternative ung spacers compared sa palit ng spring mismo? tnx
March 11th, 2010 02:16 PM #2
- Mar 2010
- 19
March 11th, 2010 02:58 PM #3noted on that. but will the spacer lessen or minimize ung mga time na sumasabit ung tires? will it increase height?
thanks
March 11th, 2010 03:39 PM #4
Well, the rubber "lifter" will increase the suspension height by the thickness of the spacer. It would help minimize the rubbing of your tires against the fender.
One method used to minimize tire rubbing is to have the fender lip "rolled". It is effective if you only need a minimal amount of added clearance. SPEEDLAB has the proper tool to roll your fenders.
March 11th, 2010 06:55 PM #5
It'll depend on why it's rubbing. If it's rubbing because it's too wide, it'll help a little... but if it's rubbing because it's too low, it'll help a lot. Rolling the fender is a more complete solution.
I had to do both with my car. Mags were too wide and car was too low.
- Mar 2010
- 19
March 11th, 2010 07:03 PM #6thanks guys. its rubbing bcoz its too low i think... ill go with the spacer first then drive if i need more, fender rolling is next... thanks
appreciate more inputs
March 11th, 2010 07:53 PM #7
You can have the spacers fabricated at Cruven for about 300-400/ pc depending on the thickness you need.
- Mar 2010
- 19
March 11th, 2010 07:58 PM #8speaking of thickness... what's the maximum height that is advisable to use for spacer? 2, 3, 5, etc inches?
is there sort of efficient limit?
March 11th, 2010 08:50 PM #9
It actually depends on what you will be needing to solve the rubbing. As for me, I'm using 1.5" for the front and 3" for the rear for a Nissan X-trail which is quite high. Maybe an inch or 1.5" would solve your problem. Anyway, you can ask them to measure it for you. Hope this helps! Goodluck!
- Mar 2010
- 19
March 12th, 2010 07:23 PM #10
What vehicle and what's your budget?
