Results 11 to 20 of 30
- Jun 2005
- 3,774
July 11th, 2012 08:30 AM #11if that happened to me, wi'll just find another shop to have my car fix.
seriously, nung binuksan nila, hindi dapat linis lang. dapat overhaul the caliper and use a caliper kit. shortcut naman kasi ginawa ng mechanic nyo.
July 11th, 2012 10:10 PM #12
suspect parts imo considering the age of your car and assuming no brake jobs before:
1. internally split brake hoses, could be due to old age or clamping the hoses before (pressure is contained and is not pushed back to the master cylinder when released)
2. piston seals worn out and lost its "spring action" (won't push the piston back to its released position)
3. master cylinders (rubber caps may be expanding and covers the compensating port when the brake fluid is heated)
4. proportioning valves/metering valves etc - might be out of proportioning action
brake booster is a remote possibility of locking up the front.
try mo na lang sa ibang service shops. wag ka na bumalik sa dati mo mechanic obvious na hindi sila marunong at gusto lang perahan sa back jobs.
July 11th, 2012 10:12 PM #13
1. internally split brake hose (pressure is contained and is not pushed back to the master cylinder when released)
July 11th, 2012 10:36 PM #14
don't forget the age of the brake fluid. if the fluid is older than two years or if the fluid has been exposed to the moisture in the air, the boiling point drops and it causes abnormal expansion creating pressure that makes the brakes drag
- Apr 2010
- 71
July 13th, 2012 04:19 PM #15Sirs, just an update lang po. I followed your advices, I brought my car in other shop and they overhauled my 2 calipers (again) then replaced a new caliper kit. Unfortunately, my 2 brakes are still having the same problems...kasi when I got home (its just about 10mins drive from the shop), hinipo ko ang mags at umiinit pa rin po.
Inadjust na nga nila un parang stick sa hydrovac na nagpupush sa brake master pero ganun pa rin :-(
- Apr 2009
- 429
July 14th, 2012 07:24 PM #16hi PA, your trouble seems to be not in the calipers. Sticking brakes usually point to air packets trapped inside your brake system. Causes are aplenty, the most common being inadequate bleeding when a mechanic changed some rubber seals (this is, if you had your brake's rubber cap or caliper kit changed before you had this problem), another is, since, your car is more than 20 years old (but still mechanically reliable as you mentioned), parts do breakdown, and I suspect the internal bore of your master cylinder became bigger due to wear and tear or the rubber seals (repair kit) of the master cylinder are worn out leading to "regurgitation" of the brake fluid to the reservoir and inviting air packets. With this condition, brake fluid can also leak back into the insides of your hydrovac causing havoc. Your mechanic adjusting the push rod b/n the hydrovac and the primary master is a BIG NO NO as this will disturb the Physics set by the manufacturer and will make your brake the more unreliable. Once this pushrod is touched, I assure you, your brakes will never be normal again. I suggest you change both your hydrovac and primary master with the SAME model and specs. Surplus is ok, but install a brand new repair kit (brands like SEIKEN, AISIN, ASCO, etc) for the primary master. Other things that you should address are the ff: 1- Change your flexible brake rubber hoses front and rear, 2- overhaul or change (if the insides are rusty, ragged or leaky already) the rear wheel brake cylinders, 3- inspect or replace defective proportioning valve or splitter fittings, 4- do a full brake bleeding after addressing all the problems mentioned above. Start bleeding your brakes from the farthest wheel to the nearest (from your primary master). 5- change brake fluid every 2 years, sooner if you wade your car in flood waters. Look for a mechanic who truly understand the brake system. Not to offend some out there, but, many "backyard" mechanics are mediocre when it comes to understanding the brake system
good luck...
- Apr 2010
- 71
July 14th, 2012 08:42 PM #17Negative sir LN106G, the only parts that were replaced about a month ago before this happened...is the brake master kit, un pa lang po ang napalitan sa brake system ko last month. Yesterday lang po kami nagpalit ng new caliper kit.
By the way sir, are you sayin that my hydrovac is already busted and time to replace?
Its a bit pricey po kasi thats why we're starting to troubleshoot from the small things first, Im planning to replace my front brake hoses next week, isa daw po kasing factor yan sa present problem ng car, hopefully masolve na po after we installed new hoses...but eventually if the problem still comes out, I got no choice but to get a new hydrovac. Thanks
- Dec 2010
- 87
July 14th, 2012 09:31 PM #18Hi pamela, sa tingin ko nasa type ng brake fluid at bleeding procedure lang yan eh. DOT 4 ang pinakamaganda kase high temp yang fluid na yan. tapos sa bleeding sequence, yung rear wheel ang unang binibleed and make sure na wala ng bubbles ang rear bago mag bleed sa front wheel. and yung bushing sa gilid ng caliper assembly dapat nilagyan nila ng grease para ndi mag stick. - cheers
- Apr 2009
- 429
July 15th, 2012 11:13 AM #19[QUOTE=PamelaAsistio;1966263]Negative sir LN106G, the only parts that were replaced about a month ago before this happened...is the brake master kit, un pa lang po ang napalitan sa brake system ko last month. Yesterday lang po kami nagpalit ng new caliper kit.
Then that's probably where your problem started. The previous mechanic who worked on it must not have bled your system adequately. The most logical thing to do first is to rebleed your system properly starting from the farthest wheel to the nearest one (to your primary master). Try to observe the brake fluid reservoir while pumping your brake pedal, if it shows fluid regurgitation or bubbles consistently then your primary master is no good and you have to replace it. (this means maluwag na specified inside bore and even with new repair kit will not solve your problem). To know if your hydrovac is still ok, shut off your engine then pump your brake pedal until it becomes hard (if it does not become hard with several pumps, your hydrovac is no good), while steadily stepping on your "hardened" brake pedal, start the engine. Once the engine starts, notice if your brake pedal becomes softer while stepping on it and should stop a little midway through its play signifying a good and functioning hydrovac. This is one way of testing your hydrovac. But looking at your situation, your car being more than 20 years of good service, It is better to change your Hydrovac and primary master as one with the SAME model and specs. Your mechanic adjusting the push rod b/n the h-vac and primary master is a NO NO as this will create untraceable problem sooner or later. This I assure you. It is also wise to change your flexible brake hoses as well as service or change defective rear brake cylinders in one sitting to eliminate guesswork and will save you time and money in the long run. If your mechanic is knowledgeable, he will change them one at a time, bleed them one at a time, then doing a general "neurotic" bleed thereafter. A mechanic disassembling them at the same time will be inviting a lot of air packets and bleeding it will prove tricky.
BTW, a surplus hydrovac and master as well as flexible brake hoses are not that expensive.
Yes, they sometimes command a price, but, hey its your life that's on the line once you get inside your car...
cheers...
July 15th, 2012 10:08 PM #20
if you changed your master cylinder cylinder repair kit, chances are the replacement primary piston cavity where the push rod sits has a shallower cavity than the original and the push rod is too long for that replacement piston that, since it is somewhat pushed forward while the brake pedal is fully released, the primary compensating port is being blocked by the piston and the piston rubber cap preventing brake fluid from returning to the reservoir. have the push rod adjusted with about 1 mm clearance or freeplay. do not replace anything yet that had been guessingly recommended by mechanic A, mechanic B, mechanic C and mechanic guess
Turbo timer yung feature na yan sa Everest? Sana default feature yan sa mga naka turbo na sasakyan.
0dometer problem
