Results 11 to 14 of 14
April 4th, 2012 04:20 PM #11
As long as it falls on the same grade level e.g. Dexron III as recommended by your car manufacturer it should be safe.
April 4th, 2012 10:09 PM #12
As a general rule: If changing any kind of fluid/lubricant, it is always best to fully purge/flush all the old liquid before putting on the fresh fluids. Its okay to mix two different power steering fluid as long as they conform to the recommendation of the manufacturer.
But it sure would be better if you only use one type of PSF on your system.
April 4th, 2012 10:37 PM #13
Suzuki rin ang ride mo diba sir olidotcom?
The Jimny accepts any kind of shitty ATF. hehe. Seriously Dex III ata. The APV should have it in its manual. Just don't mix different types but it's ok to mix different brands as long as they are the same type.
A complete drain and refill is always ideal but when unable to do so immediately, your PS system won't self destruct.
April 5th, 2012 07:25 PM #14
OT:
I think the same holds true for mixing of brake fluid as long as same type is used e.g. DOT 3. Based from what i read, ung coolant ang dapat huwag i-mixed, preferably same brand dapat pag coolant.
Naglabas daw Ng delicą 4 x 4 Ang Mitsubishi ph Ng mid 2000s ? Is that true?
Mitsubishi Philippines
