Results 1 to 10 of 11
- Apr 2008
- 39
March 9th, 2013 08:04 PM #1Magandang gabi po! nag pa replaced ako ng 4 tires ko, automatically dapat ipa wheel balancing and alignment and camber sya. ok na yung balancing then naayos na rin ang alignment at camber ng auto ko (Php 1,500 ang bayad). so nung inuwi ko na, ok sya at walang kabig pero nung malapit na ako sa bahay biglang nagkaroon ng kabig pakaliwa pag binibitawan ko manibela e mejo malayo yung binilhan ko ng gulong. ano kaya possible cause nun para pagbinalik ko e ma check kong maiigi. Salamat po!
- Jun 2010
- 321
March 9th, 2013 08:47 PM #2balik mo sa wheel alignment shop may warranty naman yan 30 days,try mo pag palitin yung 2 gulong sa harap, pag may kabig pa rin sa alignment ang problema pag lumipat naman sa kanan ang kabig most likely gulong nga
- Apr 2008
- 39
March 9th, 2013 08:59 PM #3
March 11th, 2013 11:22 AM #4
March 11th, 2013 04:12 PM #5
- Apr 2008
- 39
March 11th, 2013 08:59 PM #6wala po printout, ok din po tire presurre, nitro pinalagay ko po (34 psi). binalik ko after office, hindi kasi ako mapakali,,, he he. problem daw is with "caster" usually daw e lumalabas daw ang kabig after alignment... totoo kaya to o binobola lang ako nung mechanic? after nya ma galaw ung "caster" ok na takbo, wala na kabig, hopefully tumagal na ok ... mejo malayo dinadalhan ko.
- Jul 2003
- 573
March 16th, 2013 05:50 PM #8
March 17th, 2013 03:39 PM #9
check other possible causes: check your brakes, check your wheel bearings, check the wheel preload, check vehicle ride height and check for worn or broken suspension components
- Dec 2012
- 220
April 16th, 2013 08:05 AM #10Sa lumang gulong ba walang kabig? Had an alignment problem before turns out yung mags ang problem.
in my opinion, the more effective deterrent against car theft, is the visible deterrent. if the...
