Results 1 to 11 of 11
    Apr 2008
    Magandang gabi po! nag pa replaced ako ng 4 tires ko, automatically dapat ipa wheel balancing and alignment and camber sya. ok na yung balancing then naayos na rin ang alignment at camber ng auto ko (Php 1,500 ang bayad). so nung inuwi ko na, ok sya at walang kabig pero nung malapit na ako sa bahay biglang nagkaroon ng kabig pakaliwa pag binibitawan ko manibela e mejo malayo yung binilhan ko ng gulong. ano kaya possible cause nun para pagbinalik ko e ma check kong maiigi. Salamat po!
    Jun 2010
    balik mo sa wheel alignment shop may warranty naman yan 30 days,try mo pag palitin yung 2 gulong sa harap, pag may kabig pa rin sa alignment ang problema pag lumipat naman sa kanan ang kabig most likely gulong nga
    Apr 2008
    Quote Originally Posted by raycon_24 View Post
    posibleng magkaproblem yung gulong kahit brand new? try ko muna pagpalitin yung gulong, next week ko p maibabalik e.
    Quote Originally Posted by markuz14 View Post
    Factory deffect? baka oblong yun gulong na nakabit?
    May 2009
    hindi yan kakabig kung oblong ang gulong...parang kabayo yan kung oblong at matinding vibration.
    Feb 2009
    check other possible causes: check your brakes, check your wheel bearings, check the wheel preload, check vehicle ride height and check for worn or broken suspension components
    very rare ito ah.
    baka naman hindi lang pantay yung tire pressure mo.
    may printout ka ba nung sa alignment? ok naman ba values na nakalagay after alignment?
    Apr 2008
    Quote Originally Posted by 1D4LV View Post
    very rare ito ah.
    wala po printout, ok din po tire presurre, nitro pinalagay ko po (34 psi). binalik ko after office, hindi kasi ako mapakali,,, he he. problem daw is with "caster" usually daw e lumalabas daw ang kabig after alignment... totoo kaya to o binobola lang ako nung mechanic? after nya ma galaw ung "caster" ok na takbo, wala na kabig, hopefully tumagal na ok ... mejo malayo dinadalhan ko.
    Jul 2003
    palagay ko eh may nalimutan higpitan sa adjusters.
Kabig pakaliwa
