Results 1 to 10 of 15
- Jun 2003
- 58
September 30th, 2005 02:57 PM #1need to replace my XUV's tires.. 235/70 r15
what do you think is the best buy?
Michelin LTX around P4700 each?
or Bridgestone Desert Dueler around P3600 each? (totoo ba putukin sidewall nito?)
or Goodyear Fortera around P3800 each?
or any other brands you can recommend?
all the time highway driven sya, thanks in advance
October 15th, 2006 10:00 PM #2
Buhayin ko lang ang thread na 'to.
I'm now in his shoes... I'm looking for the replacement of my 4 years and 4 months old tire (56k km)... I was considering Bridgestone Desert Dueler pero heard several issues with this, so now am considering Goodyear Fortera.
Any shop that I can get a good deal for 4 pcs of Goodyear Fortera?Last edited by 20vanda01; October 16th, 2006 at 07:58 PM.
October 15th, 2006 11:23 PM #4
I've heard Forteras are pretty good, and they felt okay when I tried them on another vehicle (not a Crosswind)... am thinking of trying a set when my current Bridgestones run out.
Tsikot Member Rank 2
- 441
October 16th, 2006 02:55 PM #6
BF Goodrich ATs looks good. I might switch to these. Otherwise ok na ang stock michellines sa PhP4,700.00 ea
October 16th, 2006 02:57 PM #7
I bought a set of 235/70R15 102S RH03 Hankook in banawe last year. I think it was less than 4,300 each. Tahimik sya at di matigas ang sidewall kasi passenger category siya at hindi pang light truck.
Check it out www.hankooktireusa.com hope this helps
October 16th, 2006 05:40 PM #8
Are they load rated for the Crosswind? Sounds interesting... the reason I wanted the Forteras was because they're more car-like than the Duelers.
Checked... okay, ah... OEM siya for the E250... need to look these up...
October 16th, 2006 08:12 PM #9
The problem with my current Michelin LTX AT is slippery and poor handling on wet roads (based on my experience), even before they are still new.
The Hankook RH03 is worth checking.
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
