Results 1 to 19 of 19
    Oct 2004
    after ma repair ang brakes ko because of the stuck up nung nabaha, nagkaron ng squeal parang eeek eeek eeek habang tumatakbo between 20-30kph, pag mas mabilis nawawala and kung mas mabagal dyan wala rin.However when i step on the brakes nawawala tunog.Madalas mangyari ito pag malamig ang preno, after some time driving nawawala ito ng kusa. sabi ng mekaniko ko ok lang naman daw dahil he checked and wala naman stuck up na. Kaso its irritating lalu na pag sa eskinita ka dumadaan dahil mas dinig ang squeak ng brakes. Ano kaya cause nito?
    Brakes ba iyan? Hindi kaya bearing na contaminated?
    even w/o stepping on the brakes may noise? possible ngang bearings... imho, kasi kung brake squeal yan, noise will come out only when you step on the brakes. normal yun kung medyo manipis na brake pads mo. meron talagang audible na squealing yan, which tells you your brake pads are worn out or starting to wore out.
    Nov 2003
    baka may di nabalik na mabuti na shim or something like that.
    Oct 2004
    ang tunog nya kapareho ng brake linings pag worn out na, pero bagong palit ko lang brake pads sa harap. It goes away when i step on the brakes, pag bitaw preno eek eek eek na naman, usually lang naririnig ito at 20-30kph. Kala ko nung una naninikit na naman brake sa harap pero nung pina check ko sa mechanic wala naman daw stuck up. Di rin siguro bearings kasi at higher speeds than 30kph nawawala, kung bearings dapat bibilis ang tunog pag bumilis takbo.at lower than 20kph wala rin tunog. Nababaliw nako kakahanap kung ano dipresnsya hehehe
    Quote Originally Posted by bratski View Post
    Not always.
    Aug 2006
    less likely the brakes, I'm guessing at least one of the bearings...
brake squeal
