Results 1 to 10 of 56
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 19th, 2006 08:42 PM #1Help naman. Di mawala yung problema ng preno ko. Repairs done to date:
1. New brake pads
2. New brake master
3. Replace pc valve sa hydrovac
4. bleed and flush brake fluid
Problem: Malalim yung preno pagmalamig yung makina. Di naman lubog pero masmalalim kaysa normal. Pag normal operating temp na yung engine ok na yung preno. Di ko maintindihan ano ang problema. Thanks in advance.
August 19th, 2006 09:24 PM #2
August 20th, 2006 12:37 AM #3
Try to bleed the system properly (per wheel).
Is your engine making enough vacuum?
- Jun 2006
- 2,605
August 20th, 2006 10:46 AM #8Ok pa bleed ko ulit. Considered as backjob to diba?
what vehicle is this, diesel or gasoline?
August 21st, 2006 05:31 AM #9
wala ako idea regarding sa ganyan... since bagong ayos lang iyun brake system sa kotse mo i think kailangan ibalik mo sa casa/talyer at ayusin nila ulit with no extra charge...
and bantayan mo trabaho nila dahil may mekaniko na sabihin na inayos na nila pero ang totoo hindi... or may magalaw sila at nasira sabihin nila ganito ganyan sira na kailangan palitan... gastos ulit... iyun lang...
sa akin kahit sabihin ng service keyso bawal ganito ganyan... eh hindi ko sila pinapansin at wala ako pakialam basta nagbabayad ako ng buo at gusto ko bantayan sasakyan ko, tapos...
- Aug 2006
- 337
August 21st, 2006 09:03 AM #10What make/model?
Engine vacuum cleaner(hehe)has nothing to do with your braking problem.
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
