Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 98
    Dec 2017
    #21
    Dami sa True value. Permatex yun maliliit na sachet lang.
    Where is True Value? Is that a store? Sorry, I didn't do a search...
    #22
    Yes. Mall based hardware. They have permatex greases for spark plug thread, headlight bulb terminal, batt terminal, oil plug Thread and I believed I've seen that particular one for caliper.
    Less than ₱100 lang per sachet, and it's more than enough for couple of cars.
    #23
    They're found mostly in Ayala malls.
    Sent from my SM-T705 using Tapatalk
    Dec 2017
    #24
    Thanks! I might be in Makati so I might visit that store.
    May 2013
    #25
    Napaisip tuloy ako doon sa binili kong wurth from true value [emoji58][emoji58]
    Sent from my SM-C900F using Tapatalk
    Oo nga bro eh. Hahahah. Yan pa naman plano ko bilhin. Naguguluhan tuloy ako.
    Bendix is synthetic (its like a all in one grease), which is also applicable sa metal to rubber. But, Ive read if the grease is not silicone, it might swell the rubber, even if its synthetic and applicable. Thus I was planning on buying the wurth. Now, meron pala permatex sa true value. Whew!
    Hirap pag ang dami mong natututunan. Oc na nga, lalo pa dumagdag sa ka oc-han.
    Quote Originally Posted by bugoys View Post
    There are 3-4 kinds of permatex brake grease... 2 dont work well with rubber boots.
    #27
    Eto yun nilagay ko sa caliper pin ko bro, along with the rubber boot. Im not worried too much about the vios since around 1k lang yun repair kit. Pero sa swift kasi, baka mahirapan ako maghanap.since ginamitan ko rin nito
    Quote Originally Posted by Vodka View Post
    at True Value marquee (pampanga)
    #28
    Sil glyde kaya dapat ilagay sa pin?
    Feb 2014
    #29
    Quote Originally Posted by jmpet626 View Post
    Meron sachet ng Wurth caliper grease. Around 75 pesos nung Car show sa SMX sa Wurth Booth. Good for 4 calipers na. Nasa 100 pesos na siya sa Fix stop nung last na bumili ako. Before ang hirap talaga maka hanap umorder pa ko sa Amazon ng Permatex Ceramic caliper grease pero much better yung wurth.
    this post put me in the wrong path the wurth brake paste paste is NOT a silicone grease. it's more of a metal powder anti-seize w/ mineral oil so it's for the back of the pad and in the shims and tabs. NOT for the caliper pin
    thanks for prompting me to investigate. now i'll be looking for a suitable silicone grease...
    #30
    Bro i think pwede naman. Nalagyan ko na both cars, update ko thread if ok naman sya.
Grease for brake caliper pins
