Page 1 of 4 1234 LastLast
Results 1 to 20 of 98
    Feb 2014
    it's been 3 years since i last changed the brake fluid on the honda so i'll be replacing the fluid, change brake pads, and do general brake service
    what to use on the caliper pins that's locally available? i have PLAIN silicone grease lying around, is that ok? it doesn't have any moly or graphite additives it's just a thick plain silicone grease
    Mar 2005
    Quote Originally Posted by Vodka View Post
    Meron sachet ng Wurth caliper grease. Around 75 pesos nung Car show sa SMX sa Wurth Booth. Good for 4 calipers na. Nasa 100 pesos na siya sa Fix stop nung last na bumili ako. Before ang hirap talaga maka hanap umorder pa ko sa Amazon ng Permatex Ceramic caliper grease pero much better yung wurth.
    Feb 2014
    Quote Originally Posted by jmpet626 View Post
    thanks i'll look for that
    what does it look like? just translucent white like petroleum jelly?
    Still 75pesos per sachet. Found in some handyman stores. Nakakita ako sa handyman galleria.
    Feb 2012
    Caliper grease - yan ba yung para hindi mag-chatter yung brakes? Sa Concorde meron nyan. Nasa lata siya. Parang thermal grease (Arctic Silver) ng CPU heatsink ang hitsura.
    Sent from my LG-H962 using Tapatalk
    Feb 2014
    Quote Originally Posted by gearhead000 View Post
    the grease used behind the brake pads is different
    the wurth grease they're talking about goes into the slider pins. silicone so it won't hurt the rubber boots of the pins. i used to have a ford lynx w/ seized caliper because of neglecting the slider pins so lesson learned LOL
    wala tingi nito bro diba? magkano yung nasa can?
    san yung fix stop located?
    Feb 2014
    at True Value marquee (pampanga)
    Mar 2005
    Yung Fix Stop sa may congressional ave qc siya located. Gamit ko din to as anti rattle grease sa likod ng backplate ng brake pads. So far ok naman.
    ^thanks bro
    May 2013
    I've been reading about grease/lube for the brakes in the forum, for about an hour na. Basically, there are 2 brands, wurth and bendix, na for brakes talaga. Does the 2 products function differently? Somepone posted na yung wurth is pang caliper boot lang, while I read online na yung Bendix, is applicable for metal to metal and metal to rubber.
    mga bros quick question, sa brake caliper boot ba. dapat yung gilid lang ba (highlighted in yellow) or kasama pati loob (highlighted in red)?
    Eto yun nilagay ko sa caliper pin ko bro, along with the rubber boot. Im not worried too much about the vios since around 1k lang yun repair kit. Pero sa swift kasi, baka mahirapan ako maghanap.since ginamitan ko rin nito
    Sent from my SM-C900F using Tapatalk
    Dec 2017
    I haven't tried this, but I think this good for metal to metal and metal to rubber.
    1 lube for all brake parts:
    Amazon.com: Permatex 8653 Silicone Extreme Brake Parts Lubricant, 8 fl. oz.: Automotive
    yes this is the right one. It won't warp the rubber boots. I only ordered the small tube :D
    Sayang sana nagpasabay ako [emoji26]
    Di ko pa Alam kailan dadating[emoji848]
    Pwede siguro yun post ni bro vodka, lazada naman
    Dec 2017
    Dami sa True value. Permatex yun maliliit na sachet lang.
Grease for brake caliper pins
