Results 1 to 10 of 12
- Apr 2009
- 549
July 28th, 2010 11:33 AM #1hi to fellow tsikoters..
I noticed that the left side rear (inner) wheel have oil stain actually sa right side meron din pero mas slight. Is there something i could do, masama
ba ito or normal lang? I'm thinking baka oil seal sa differential pero yung right side ko pinalitan ko ito less than a year pa lang.
need your comments and suggestions
thanks
i have pictures but can't figure out how to add image.
paturo paano?
- Apr 2009
- 549
July 28th, 2010 11:51 AM #2ito yung pics. na research ko na paano hehehe.
http://img266.imageshack.us/gal.php?...rear728102.jpg
July 28th, 2010 12:16 PM #3
- Jul 2003
- 573
July 29th, 2010 04:55 AM #4cannot open the link to your picture.
it may be brake fluid that is leaking.
better inspect your rear brakes.
July 29th, 2010 06:58 AM #5
try to touch the leak and smell it to know if it is an gear oil leak or a brake fluid leak.
kung gear oil leak malamang yung oil seal ng wheel bearing yun. ang kuha ko sa mga parts noon nung magparepaair ako ay ito.
oil seal php100/pc
wheel bearing php450/pc
axle lock php120/pc
nagka oil din yung sa akin noon kaya pinalitan ko na lahat para isang labor na lang.
- Apr 2009
- 549
July 29th, 2010 09:46 AM #6hi thanks sa mga advice.
ito try ko uli post ang pics. yung tagas naman d umaabot sa rim ng gulong.
http://img72.imageshack.us/i/crosswi...rear72810.jpg/
http://img843.imageshack.us/i/crossw...ear728102.jpg/
- Jul 2003
- 573
July 29th, 2010 11:48 PM #7there is nothing serious on those pictures. I don't think there is a leak. try cleaning it with detergent and water, then check it again after using your ride.
July 30th, 2010 12:04 AM #8
Namamawis ng langis. So long as its not dripping on the floor and the level in the pumpkin is not dropping (checked by inserting finger into fill hole), you'll be ok. It really happens as vehicles get older.
If you want to be O.C. about it, clean the area first and observe where the fluids emerge.
Sometimes it can come from another source (e.g. small leak on the piston of the drum brake) or where the hard brake lines enter into the drum brake (its on top, where the bleeder is located also).
Were the brakes bled some time in the past? It could just be brake fluid residue.
- Apr 2009
- 549
July 30th, 2010 03:46 PM #9yes it was bled a month ago. Brake shoe replaced. hindi naman nagbabawas
ng brake fluid sa reservoir. worry ko baka worn out na oil seal or someting.
anyway i will try to clean the area. and check differential oil
thank you all.
- Oct 2018
- 4
October 16th, 2018 04:22 PM #10it sounds your axle had already hairline crack. Your symptoms is the same as mine and later on the axle sheared problem and totally crack which can later cause unexpected accident.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
