Results 1 to 12 of 12
    Apr 2009
    hi to fellow tsikoters..
    I noticed that the left side rear (inner) wheel have oil stain actually sa right side meron din pero mas slight. Is there something i could do, masama
    ba ito or normal lang? I'm thinking baka oil seal sa differential pero yung right side ko pinalitan ko ito less than a year pa lang.
    need your comments and suggestions
    thanks
    i have pictures but can't figure out how to add image.
    paturo paano?
    Apr 2009
    ito yung pics. na research ko na paano hehehe.
    http://img266.imageshack.us/gal.php?...rear728102.jpg
    Quote Originally Posted by anthon05 View Post
    thanks
    paturo paano?
    Malamang oil seal yan, di siguro maganda pag kakabit. or worn out na.
    Jul 2003
    cannot open the link to your picture.
    it may be brake fluid that is leaking.
    better inspect your rear brakes.
    Jun 2009
    try to touch the leak and smell it to know if it is an gear oil leak or a brake fluid leak.
    kung gear oil leak malamang yung oil seal ng wheel bearing yun. ang kuha ko sa mga parts noon nung magparepaair ako ay ito.
    oil seal php100/pc
    wheel bearing php450/pc
    axle lock php120/pc
    nagka oil din yung sa akin noon kaya pinalitan ko na lahat para isang labor na lang.
    Apr 2009
    hi thanks sa mga advice.
    ito try ko uli post ang pics. yung tagas naman d umaabot sa rim ng gulong.
    http://img72.imageshack.us/i/crosswi...rear72810.jpg/
    http://img843.imageshack.us/i/crossw...ear728102.jpg/
    Jul 2003
    there is nothing serious on those pictures. I don't think there is a leak. try cleaning it with detergent and water, then check it again after using your ride.
Crosswind Differential leak?
