Results 11 to 12 of 12
- Apr 2009
- 533
November 21st, 2018 01:02 PM #11
Hi All
Sorry for the very late feedback ( after 8years)
I did have my oil seal replaced that time and no leaks after that.
just want to ask also on the crosswind owners, if they already have their axle hub bearing replaced?
mine after 18 years replaced one of the bearings. much work done compared on replacing the front wheel bearings.
akala ko same as the front bearings which I have it replaced few years ago, even if its not yet damaged I have it replaced. sa rear or axle bearing
you need pa to machine press in and out just to remove /install the bearing.
- Oct 2018
- 4
November 27th, 2018 02:20 PM #12Your right sir. My isuzu xtrm left rear axle was suddenly broken with a warning earlier symptoms of leak fine oil (not oily it seems a combination of water and break fluid and you can sensed on your smell unrecognizable on what kind of substance.)
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
