Results 1 to 15 of 15
    Dec 2007
    I haven't watched the video pero from what I know, it's the proper setting of the coilovers paired with camber plates that will give you the advantage.
    Sent from my ASUS_Z012D using Tapatalk
    Quote Originally Posted by Nelson de Leon View Post
    specific kits for specific cars. different cars have different weights.
    Dec 2017
    I think it is not a good idea to "mess up" your suspensions for an everyday car not unless you know what you are really after for in replacing it.
    Coil overs will improve handling at the expense of riding comfort unless you plan to punish your rear passengers each time they ride with you.
    passengers? you mean immediate bumpstops [emoji28]
    Coil overs even on their softest setting may not be friendly to most motorists.
    Dec 2017
    So, it is not possible to have a set-up that you simply switch between "comfort" and "track" mode.
    [emoji3]
    [emoji3]
    Some performance cars do offer that option for their suspension setup.
    aftermarket
    if you want to control suspension setting (stiffer/softer) from inside the car
    Tein EDFC
    Dec 2017
    Just when I thought this thing doesn't exist.
    Anyways, I don't have the guts to mess up the stock suspensions of the car yet!
    [emoji1]
    Mar 2005
    [emoji1]
    I've had coilovers... they're awesome when you're at speed... nagiging stable bigla yung kotse, kahit maraming imperfection or dips sa kayle. I remember whenever I ran fast through and jumped the southbound way of Guadalupe bridge. unstable sya noong KYB lang shocks ko... pero with coils (and even now with bilstein+H&R) stable ang landing at speed...
    Pero I had to give up on coils coz they blew too often. I decided better to go Bilstein HDs instead para long lasting naman.
    Dec 2017
    Quote Originally Posted by Bravoexo View Post
    What do you mean when you say, "they blew too often"?
    He means the seals fail often resulting in leaks. Coilovers are rebuildable though.
    Sent from my P01MA using Tapatalk
    Jun 2018
    I've had Bilstein HD on my Ford Focus, not really true on long lasting kasi normal driving lang ako most of the time. Isang beses ko lang na-track yung car ko, pero one of the front shocks, has this "lagatok" when on low speed unstable roads. Pero on highspeed unstable roads, no noise.
    Back to the question, yes, coilovers will give you good handling and plus you can adjust the height and the damper settings but you will suffer on the comfort side. Kahit pinaka-soft setting, it is still harsh.
    Malala pa, if you have man-boobs, aalog alog talaga lalu pag sa EDSA.
Coilovers
