Results 1 to 16 of 16
    Jun 2009
    Seemingly new tires can actually be past an "expiration date" and pose danger to those using them. Known as "aged tires", their tread can actually separate while you're driving. At highway speeds, the results have often been fatal. If you have an unused tire that's over 6 yrs old, be wary of using it, according to this link from ABC News: http://abcnews.go.com/Video/playerIndex?id=4826897
    Mar 2005
    Naalala ko dati sa Lancer Pizza ko orig tires pa yung nasa rear mga 9 years ng gamit. Bigla na lang na flat ng dahan dahan kahit walang butas or visible damage sa tire. Kaya dapat pag bibili ng goma dapat ma check yung manufacturing date ng goma.
    Dec 2007
    Rubber deteriorates even when not used, so this is good advice.
    If you have an extra set of tires, it's best to store them somewhere away from light. UV radiation ages tires too.
    Don't forget to check your spare tire's age. If all of your tires are new but your spare is past six years old and already corroding in its well, you better pray you don't get a flat until you replace it.
    Aug 2006
    Sa abroad we don't use tires that is already 5 years old from the production date, so here I do the same. Kaya pag nakakakita ako ng mga nagbebenta ng 2nd hand tires at surplus napapa-iling na lang ako.
    We also look always sa thread wear, pag lumabas na yung embossed parallel mark sa main grooves it's time to replace it. BTW all tires have this embossed parrallel mark, if you look closer sa main groove ng tires pag inikot mo may makikita ka sa kanal na embossed parallel mark. Eto yung indicator na kailangan mo ng palitan yung tire pag litaw na at napupodpod na.
    We also buy tires from premiere tire dealers like for example Yokohama main dealers to get the freshest production batch.
    Aug 2003
    i remember one time when i noticed the car veering to the right while driving; inuwi ko kaagad, and upon inspection nagkaron na ng cracks along the sidewall ung front wheel. At the time matagal kasing natingga ung kotse sa bahay, as in once a week lang ginagamit for 4-5 years. Buti na lang di ko pinilit at baka sa EDSA pa ako nasabugan B)
    Then again, the car also had 1 or 2 Goodyear Invicta tires that were still relatively OK after all those years. Nagcomment nga ung isang mekaniko, na phase out na ung replacement for that tire model, buti buhay pa B)
    i also bought a pair of GT Champiro S'; they still looked OK when i bought it, though i had doubts that they were old stock. At the time i thought, 1.3K per piece? Hell yeah! After mga 2 years, bigla na lang pumutok ung isa while parked; no puncture holes or anything, nagcrack siya along the threads, luwa pati ung steel wires. Again, blessing in diguise at di ako nasabugan while driving.
    La bang nakastamp na production or expiration dates sa mga gulong?
    Matroon nakalagay na stamp code sa goma kung anong year ito ginawa. Expiration wala ata.
    Aug 2006
    Lahat ng gulong may production date sa side wall, usually first 2 digits is year and followed again by another 2 digits which is the week number.
    example 0947
    09 is the year
    47 is the week number.
    Expiration is 5 years from manufacturing date.
    Aug 2006
    Sa mga bumibili ng 2nd hand tires for spare tire, tignan nyo mabuti ang main groove minsan inu-uka nila para magmukhang makapal, re-groove ang tawag doon. Pag re-groove wala na rin yung worn out tire indicator.
    Aug 2005
    sample ng date of manufacture stamp:
    Manufactured 2008 work week 32
    December 2007 bumili ako ng 1 pair of tires to replace iyong pudpud na. pero mga aroung 20% pa iyong tires. ng check ko ang spare tire ng 2nd hand ZZ namin, may buhok-buhok pa, parang hindi pa nagamit. ng i check ko ang manufacturing date, 2001 pa pala. 2001 nabili ng first owner ang ZZ na ito. Nakakahinayang kasi looks almost new pa. Now iyong isa sa mga pudpod ang spare tire kasi 3 years old pa lang itong papalitan ko.
    Dec 2007
    Quote Originally Posted by Mile2 View Post
    example 0947
    09 is the year
    Actually it's the other way around. The code should read "4709"
    The first two digits are always the week number. The last two digits are the year number. So in the example above, the tires were manufactured on the 47th week of 2009.
    Dec 2007
    Agreed. The "wear bars" are always there regardless of whether the tire is new or old - they should be, because that's your reference.
    When the tire tread area is worn down to the point that it's on the same level of these wear bars, that's when the tire needs replacement ASAP - even if it hasn't hit 5 or 6 years.
    Aug 2006
    Quote Originally Posted by Type 100 View Post
    Your are right thanks for the correction.
    Feb 2006
    yeah old tires are really dangerous. a friend of mine bought brand new never been used (may buhok buhok pa) tires from a seller online for a very very low too good to be true price. he picked it up night time and didn't bother checking the production date. when he had it mounted, napunit yung tire. when he checked 97 yung production date amf! hahaha...
    May nabasa ako, yung crack daw sa gulong lagyan daw ng mighty bond
    May 2018
    Biro lang naman ito, we know
    But I wouldn't even use yang mga "Mighty Bond" para magrepair ng suelas ng rubber shoes.
    Didikit nga, but it hardens, tapos lulutong yung tumigas na goma.
    It won't be long madudurog yung tumigas na goma.
    Tires have a “shelf life” of 5 years old. Anything beyond that it is already dangerous to drive around with expired tires.
    So when buying tires always ask for the production date. (You can see this printed at the tire sidewall) As much as possible only buy tires that are at least a year old. Newer, better.
Hidden Dangers of Tires that Look New But Are Actually Old
