Results 1 to 10 of 17
July 6th, 2005 12:23 AM #1
I'm planning on changing my stock 15 inch wheels for the 17 inch type alloy rims. What are the advantages/disadvantages of doing such?
July 6th, 2005 12:37 AM #2
advantages: The "porma" factor, better handling.
disadvantages: Ride quality suffers if you don't change springs / shocks, 17" tires ain't cheap.
01 EX Ody
- 437
July 6th, 2005 03:43 AM #3aside from being off the speedometer...
http://www.miata.net/garage/tirecalc.html
July 6th, 2005 05:24 AM #4
Kaya pala ang stock 17" ng MZ3 205/50/17 at sabi ko bakit hindi ginawang 205/40 or 45. Its to minimize the off reading of the speedometer. But it looks like I can upgrade the tire to 215/45 and 1% lang differential. Kung kakasya, 225/45 and a 0.4% too slow lang ako.
Doc Diesel, thanks for the link.
July 6th, 2005 06:38 AM #5Originally Posted by Doc Diesel
in my case, changing to the new tires (same rime though) makes me travel 7.3% slower or the speedometer reads 60kph while actual speed is 64kph
tanong ko lang:
1. does this mean that i am consuming more fuel?
2. puede kaya i-adjust and speedometer to match the new tires?
July 6th, 2005 07:53 AM #6
bigger mags also mean more weight... so acceleration will be slower and more fuel will be used to accelerate the car.
July 6th, 2005 12:06 PM #8
Ride Quality - A low-profile tire such as a 50 or a 40-series looks great, but can be harsh over bumps or potholes when compared to a 55 or 60. In general, a lower profile tire also exposes the wheel to damage more easily. Lower profile tires also have stiffer sidewalls, which improves handling but increases rides harshness.... It's all about compromise and there's no such thing as free meryienda.
July 6th, 2005 01:48 PM #9
konting ingat lang pag naka 17's na and i suggest you get a rota for the durability in our roads. hehehehe
July 6th, 2005 02:12 PM #10
You can't have your cake and eat it, too.
17-inchers are definitely going to make the ride stiffer. Heavier 'pa-porma' mags will significantly increase fuel consumption and decrease performance, often to the tune of 5-10 hp at the wheels. Lighter 'performance' mags like ROTAs will minimize this consumption increase while freeing up maybe 1-2 hp at the wheels, if your stock 15s are heavy. A 17" ROTA with tire often weighs around 35-38 lbs, while stock 15s can weigh between 35-40++ lbs with tires, depending on design. Therefore, any decrease in top speed and fuel efficiency will come down to the width and height of the tire itself.
Problem with 17" ROTAs (especially with thin tires) is the increased 'bengkong' factor. Over a few years, if you go over enough potholes, they will DEFINITELY deform. Just because they're cheap and sturdy doesn't mean you don't have to be careful with them.
Isuzu mu-X to get proper facelift for 2025 model year | Autoindustriya
2022 Isuzu MU-X [2nd Generation]
