Page 2 of 7 FirstFirst 123456 ... LastLast
Results 21 to 40 of 133
    Oct 2011
    #21
    Quote Originally Posted by trucker111 View Post
    meron yan sa warren kung bosch.
    there's this store in recto, between masangkay and benavidez, na meron bendix. malaki yung store at puro headlight naka display sa labas. pasok ka sa loob. they have dispaly of brake pads in different sizes and brands. hindi ko lang alam kung original. better bring sample.
    ung LY ung malaking store doon between masangkay and benavidez, Rspecs din ni offer sa akin doon. when I ask for bendix, wala silang readily available but they could make special orders daw. maybe they will get it from other auto supply dealers. thanks sir.
    Jun 2007
    #22
    hanggang ngayon pati dito sa san pedro, laguna out of stock pa rin bendix. will try out LKC o TRW brand pads. as per advice hindi gaano mapulbos yung alin sa dalawa
    Aug 2010
    #23
    Quote Originally Posted by andrew1028 View Post
    try to ask CHIBA Auto Parts in Biņan. May Bendix sila dun...Duon ako nakabili ng Bendix brake pads for Vios.
    try to ask CHIBA Auto Parts in Biņan (infront of HINO Laguna/LTO Biņan - sa may Areza). May Bendix sila dun...Duon ako nakabili ng Bendix brake pads for Vios.
    Aug 2008
    #24
    ^ i bought mine in Resting auto supply in Platero, Binan.
    Feb 2015
    #25
    Hey Tsikoteers. For my first post I wanna ask something that concerns me most on my newly acquired 98 Galant Shark AT
    Since this incident below happened, I started NOT to step on the brake pedal when starting my car. Reading on will explain why.
    - The day after getting the car, upon starting it, while pressing on the brake pedal we noticed it was stiff /matigas. Then as the engine started, the brake pedal will start to press but the next symptom is the concern. It will stick (brakes) for a few minutes to the point that the car cannot be moved/ used until it relaxes after 5-15 mins and the car and brakes work properly.
    - Since then I only start the car without pressing the brakes. This way, no issues occur and I have been using it to this day.
    - The only other issues (might be related?) that I notice is that 1.) The brake pads are worn out as there is one or more scraping sound mainly on the rear wheels. 2.) the Drive belt (For Power Steering) is loose cause it would screech on cold starts and when turning the wheel sometimes. 3.) The engine shakes when idling on Drive (might be something else, but not the support, mechanic said servo cleaning)
    - My local mechanic said it might be the hydrovac upon qhick inspection (we described issue) but it passed the press-brake-pedal-and-start-engine-it-will-sink test. Also the brakes are really powerfull and works well.
    - Would bleeding my brake fluids be the best thing to do first and possibly fix the issue? Where is the best place?
    Cheers,
    Nick
    Cheers,
    Nick
    Aug 2010
    #26
    anong magandang brand para sa drum brake replacement?
    #27
    Quote Originally Posted by captainbackfire View Post
    Cheers,
    Nick
    Try to check the calipers.
    Mar 2015
    #28
    Cheers,
    Nick
    Cheers,
    Nick
    This seems like an vacuum(air)/hydrovac problem to me. i dunno about your cars hydro vac but if its the double diapharam type it could be that one of the diapphrams have leaked causing this sezing problem. when the car is warmed up it produces good enough vacuum thats when it releases. and functions properly.
    To me this is a potentialy fatal problem waiting to happen. I would have it checked with a good mechanic. na hindi pa chamba chamba lang. replacing the hydro vac will definitely solve this problem. huwag pa "pwedi pa yan" sa mga ganitong bagay your life and others on the road could be at stake.
    The brake fluids have nothing to do with this problem.
    Your know when you need to have your ssystem bled if : while depressing the brake parang at the point na mag stop na ang pag depress sa pedal tapos after a few sec bigla nanaman siyang lumosot. This is because air is present in the system and are is compressed as you depress the pedal.
    Cheers,
    Nick
    Cheers,
    Nick
    #29
    Cheers,
    Nick
    Cheers,
    Nick
    check the hydrovac and the master.
    Cheers,
    Nick
    Cheers,
    Nick
    Oct 2003
    #30
    Any alternative to bendix general ct? The brake dust (or what i call brake 'rust') that it produces makes my silver rims look brown! Pag nag-OEM kaya ako, mas ok? Ang pricey kasi nung OEM eh, very significant yung price difference nila.
    May 2010
    #31
    Quote Originally Posted by zechs View Post
    You are getting the bendix because its cheaper.. Oem is oem, if its not ok it shouldn't be there..
    #32
    planning to change all the brake pads of my civic fd, went to banawe in HRC to inquire,all they have is bendix and nissin brake pads, read somewhere that nissin brake pads are the oem pads used by honda, is this true? may nakagamit na ba ng nissin sa civic fd nila dito?
    whats the reason for changing your brake pads? under 3mm na ba?
    #34
    yun po kasi recommendation sakin ng casa sir e,kaso sobrang mahal naman ng brake pads sa casa,i know hindi dapat nagtitipid sa brakes kaya lang on a tight budget since ive already spent 23k for my 60,000 pms sa casa,so im canvassing kung ano ang medyo affordable but still will give you the peace of mind when driving your car.
    yun po kasi recommendation sakin ng casa sir e,kaso sobrang mahal naman ng brake pads sa casa,i know hindi dapat nagtitipid sa brakes kaya lang on a tight budget since ive already spent 23k for my 60,000 pms sa casa,so im canvassing kung ano ang medyo affordable but still will give you safety and peace of mind when driving the car.
    Jan 2008
    #35
    mahal naman ng 60k pms nyan 23k petot?? nag overhaul ba ng makina yan?
    #36
    Quote Originally Posted by bry79 View Post
    Get a second opinion. I've had Toyota Pasig recommending me to change the brake pads on my Corolla Altis before... and it only had 15,000kms of mostly highway driving at that time! Of course I knew better and did not even bother to listen to their recommendation or do a double check because i know my car and i know how the brakes feel when the pads are wearing down. My car is now at 50,000kms and i still have the original brake pads on; i have not checked the brake pads yet since i'm still about to go in for servicing (i check my pads and clean the brakes every 10,000kms) but i already purchased an extra set of pads since i can feel that i will have to change the pads soon and want the set on hand just in case.
    #37
    Oo nga po sir e, change fluids, clean air intakes, change spark-plugs, change filters... Saka iba pang kaek...ekan(sorry with my use of words), pero whats done is done... Charge to experience na lang, kaya minabuti ko tanong muna kung anong ok na brake pads kung sakali para naman hindi na masyado lumaki gastos, sa tingin nyo sir ok po ba yung nissin brake pads or go with bendix na lang?
    #38
    Actually this is the second time na sinabi na po sakin, had my brakes cleaned 2 months ago sa labas and yun din nirekomenda, its a 7 year old car so i think its high time na rin na palitan na, especially biyahe ako next month sa north.
    Jul 2011
    #39
    Ihagod mo muna daliri mo sa rotor disk (both sides). Pakiramdaman mo kung meron alon or magaspang, kung meron ipa resurface mo muna rotor disk para kuminis, then saka ka magpalit ng brakes, mapapansin mo din na hindi na ganun kalakas mag brake dust
    Nov 2014
    #40
    Quote Originally Posted by funprise View Post
    Huh. I thought this was normal. I noticed this a few days after bringing home my car (purchased brand new, now 6 months old) and it's been like that ever since. Wala rin naman napansin yung casa mechanic when they test drove it for an alignment check. How much does this pocket of air affect the braking power/distance? Nakaka-alala 'to ah.
Brake Maintenance
